emergency electrician
not sure if this is a con ed issue or for an electrician but i noticed that my hot water boiler wasn’t powering on around 5 pm. then about 830 half my duplex lights stopped working. these are on two separate panels neither of which has been touched in over a year if not way longer for the cellar panel. at a loss and looking for advice and possibly names who could help on short notice during this crisis. appreciate anything anyone has to offer and trying to not panic. have notified coned
solehappy
in General Discussion 6 years and 1 month ago
cate | 6 years and 1 month ago
object(WP_User)#5004 (8) {
  object(stdClass)#5016 (12) {
Heat and hot water is an emergency. They can’t let you go a week to 10 days without heat or hot water, that’s outrageous. Plus we’re still technically in heating season. Call them, badger them on the street, call your community board, call your council rep, raise a ruckus.
solehappy | 6 years and 1 month ago
object(WP_User)#5006 (8) {
  object(stdClass)#5003 (12) {
    string(6) "191690"
    string(9) "solehappy"
    string(34) "$P$B3y5PnYS5d9utCFv8uP0YhlGch9OKB0"
    string(21) "meritage211@yahoo.com"
    string(19) "2024-02-22 17:09:17"
  int(191690)
i am per con ed back up in a ‘jury rigged jumper cable fashion’ that still gives me no heat or hot water but at least the fridges work? they say they need inside the man hole to fix but that wont be for a week to ten days at least and will be harder with alternate side parking suspended indefinitely and the manhole access a legal parking spot. zero clarity from con ed.
JohnHancock | 6 years and 1 month ago
object(WP_User)#5005 (8) {
  object(stdClass)#5002 (12) {
    string(5) "22067"
    string(11) "JohnHancock"
  int(22067)
But if half your oanel is out they bridge the leg thats out to the other in a minute
object(WP_User)#5003 (8) {
  object(stdClass)#5004 (12) {
If they’re working on the block it’s probably them. Let them know immediately your power seems to have been cut and ask when power will be restored. If you have appliances no longer working they will prioritize you. If you just have to switch over to the other panel, could be years — my neighbor had to wait for five years for his full power to be restored.
  object(stdClass)#5001 (12) {
    string(6) "191690"
  int(191690)
con ed is outside now but hasnt approached yet. anyone have any good questions to ask to make sure i get good answers about what con ed sees as broken vs what they think is inside the house?
Arkady | 6 years and 1 month ago
  object(stdClass)#5005 (12) {
I agree w/ John. If you can’t get ConEd, a good electrician can rework the panel to distribute power where you need it as long as appliances don’t need 220. Try James Arbeeny – Bruno – 718 344 2793
object(WP_User)#5001 (8) {
    string(5) "22067"
  int(22067)
Call coned first, perhaps a rain related problem coming from the feed out in the street. Also check your brakers and reset them but it sounds like one of the power legs went down
