Electricity Bill for Ductless Heat as Sole Source
Any of you building owners who use ducless as sole source of heat have any info on their monthly electricity costs?
bocuckoo
in General Discussion 7 years and 2 months ago
Jasperrose11 | 7 years and 2 months ago
object(WP_User)#4978 (8) {
object(stdClass)#5016 (12) {
string(4) "1568"
string(12) "Jasperrose11"
string(20) "Jasperrose11@aol.com"
string(46) "http://www.brownstoner.com/forums/users/susan/"
string(19) "2007-08-11 22:06:34"
int(1568)
booisgolden – I think is the forum thread you were thinking of – https://www.brownstoner.com/forum/#!/general-discussion:mini-splits-as-sole-heat-so
Augustiner | 7 years and 2 months ago
object(WP_User)#4977 (8) {
object(stdClass)#4976 (12) {
I average 4 KW per square foot per year for heating and cooling on Mitsubishi H2i. Summer / Winter is about the same, transition times are lower of course. This January was exceptionally high at .5 KW / sqf.
From my experience HVAC heating is a mistake, especially in smaller rooms.
Ductless HVAC is the worst. because installers think it doesn’t matter where the air is being sucked from. In reality it’s very hard to properly balance the system of air supply and return, so there is a chance you are creating a vacuum and sucking in outside air into the ceiling.
greenworks | 7 years and 2 months ago
object(WP_User)#4969 (8) {
object(stdClass)#4979 (12) {
string(6) "193898"
string(10) "greenworks"
int(193898)
There is def one that touched upon cost to operate in last year — I asked it as part of a general query about using minis as sole heat source. Most people popped off on the wisdom of it but there were concrete numbers on cost. I used some prior threads to try to ascertain as well.
bocuckoo | 7 years and 2 months ago
object(stdClass)#4980 (12) {
string(5) "41458"
string(8) "bocuckoo"
int(41458)
Thanks. I believe most historic threads are with regards to design and suitability but not operation and efficiency (post install updates from owners)
object(stdClass)#4981 (12) {
string(6) "193898"
int(193898)
There was a thread or two a couple of months ago where a bunch of people chimed in on this as well, you might want to take a look for it.
object(WP_User)#4980 (8) {
object(stdClass)#4969 (12) {
string(5) "41458"
int(41458)
I am using Mitsu Hyper Heat as my sole source now in a small single family home. The heating is sufficient and comfortable and while challenged at extreme low temps, I find them practicle and suitable. I am just looking for input from others who are also using as sole source for comparable data as the systems are becoming more common in Brooklyn renovations. The data will also help those in the forum who are considering it in the future so I believe it to be a relevant topic.
object(stdClass)#4989 (12) {
If you have to ask, you can’t afford it :-).
More seriously, since (AFAIK) these units use electric resistance heat in weather too cold for heat pumps they’re probably not practicable for our climate.
