Dryer vent cleaning?
I have a gas-fired dryer that is heating but not drying nearly as well as it used to.  I suspect that the venting pipe to the outside is partially blocked.  Any suggestions on who to call to clean it out?  I haven’t found any good recommendations.  Thanks!
patient boy
in Appliances 14 years and 5 months ago
cleaningandrestorationpros | 13 years and 1 month ago
object(WP_User)#5003 (8) {
  object(stdClass)#5015 (12) {
    string(6) "177875"
    string(26) "cleaningandrestorationpros"
    string(34) "$P$BxTmWgLTaqlKPx1xBU0tga5SjKlzjZ."
    string(35) "info@cleaningandrestorationpros.com"
    string(67) "http://www.brownstoner.com/forums/users/cleaningandrestorationpros/"
    string(19) "2017-08-10 14:41:14"
  int(177875)
Cleaning And Restoration Pros LLC is a licensed, insured and certified company. Service area: Connecticut, New Jersey and New York. Services: air duct cleaning, carpet cleaning, chimney sweep, dryer vent cleaning, fire & smoke damage, tile & grout cleaning, rug cleaning, upholstery cleaning, water & flood damage. http://www.cleaningandrestorationpros.com/
dryerventguy | 14 years and 2 months ago
object(WP_User)#5004 (8) {
  object(stdClass)#5005 (12) {
    string(6) "179481"
    string(12) "dryerventguy"
    string(34) "$P$BdIQgrBuqpJoEWQN4EGJKTEojh8x0q."
    string(22) "dryerventguy@yahoo.com"
    string(53) "http://www.brownstoner.com/forums/users/dryerventguy/"
  int(179481)
http://clothesdryerventcleaning.blogspot.com have the entire dryer and the vent cleaned by a professional
wildsummer | 14 years and 5 months ago
object(WP_User)#5008 (8) {
  object(stdClass)#5002 (12) {
    string(6) "179472"
    string(10) "wildsummer"
    string(34) "$P$B4S2l65I20dK/VGKYW1wlvQSpqG1TK."
    string(27) "WilderSummer30317@yahoo.com"
    string(51) "http://www.brownstoner.com/forums/users/wildsummer/"
    string(19) "2017-08-10 14:41:13"
  int(179472)
Thank you very much for this thread. It’s very helpful. I have a similar problem and don’t know what to do. I will try out your proposal with USA Air Management. The prices sounds reasonable for me and if the service is also that good as you mentioned I think I will be very satisfied with their work.
patient boy | 14 years and 5 months ago
  object(stdClass)#5001 (12) {
    string(5) "29164"
    string(11) "patient boy"
    string(21) "boydmichael@gmail.com"
    string(19) "/forums/users/colb/"
    string(19) "2009-04-13 22:29:12"
  int(29164)
Here’s how the story ends.  I did try to clean it myself as much as I could but it wasn’t enough.  As it turns out, I had already contacted USA Air Management even before I got hooky’s response (thanks hooky!).  My experience with them was excellent.  They gave me a next-day appointment, the technician was on-time, friendly, and polite.  $90 flat fee, the guy did a fantastic job, dryer works like new again.  Definite recommend!
wholesalerbill1 | 14 years and 5 months ago
  object(stdClass)#5000 (12) {
    string(6) "178980"
    string(15) "wholesalerbill1"
    string(34) "$P$BWqWbpzPIaV.nbW7YDTL0bM6rRNc9c."
    string(17) "gwazzoo@gmail.com"
    string(30) "/forums/users/wholesalerbill1/"
  int(178980)
Buy a new dryer vent kit. They’re cheap and easy to install….. Make sure the dryer itself isn’t blocked with lint.
hooky | 14 years and 5 months ago
object(WP_User)#5001 (8) {
  object(stdClass)#5008 (12) {
    string(5) "36470"
    string(5) "hooky"
    string(34) "$P$Blbq0mzJEZ.NcafYLr1/iMf1SMMmYJ/"
    string(5) "hooky"
    string(21) "c_tinajones@yahoo.com"
    string(19) "2009-08-20 18:26:24"
    string(5) "hooky"
  int(36470)
I used these people: http://www.usaairmanagement.com/  it was so cheap and totally worth it- you should have seen the crud that they removed from my vent. And my dryer worked perfectly again after that.
levicapland | 14 years and 5 months ago
  object(stdClass)#4999 (12) {
    string(5) "55581"
    string(11) "levicapland"
    string(18) "lcapland@gmail.com"
    string(26) "/forums/users/levicapland/"
    string(19) "2010-06-10 20:49:58"
  int(55581)
How far does is the outside vent to the machine itself? You might want to try a vacuum hose depending on the distance. Keep in mind it might just be the dryer. On the other hand if there is lint buildup in the vent it is a fire hazard. Is the vent getting hot when you run the dryer? Levi Capland
SoHo Appliances
