Decking for terrace/roof
Our extension also serves as a terrace for our tenants (our bedroom roof is their terrace). It is a flat roof, sloped to a drain, with a rubberized membrane. What kind of pavers can you all recommend? Pedestal systems look good, but are very pricey – any rec’s for ones that are more affordable that will still keep our waterproofing intact?
emmajacob
Guest User | 8 years and 10 months ago
depending on what kind of roofing membrane it is you could void the warranty by installing something inappropriate – did you install the roofing?
emmajacob | 8 years and 10 months ago
object(WP_User)#4990 (8) {
object(stdClass)#5017 (12) {
string(6) "194093"
string(9) "emmajacob"
string(34) "$P$BBCD5yVVTrMuebgR3W.ItA86iwuExe/"
string(24) "emma.jacob2017@gmail.com"
string(19) "2024-02-23 13:26:06"
string(21) "Emma jacob Emma jacob"
int(194093)
Do you recommend pedestal pavers?
patrickburnsjr | 8 years and 10 months ago
object(WP_User)#5000 (8) {
object(stdClass)#5018 (12) {
string(6) "193383"
string(14) "patrickburnsjr"
int(193383)
There is no way to install “off the shelf ” decking tiles safely. They come with or without “off the shelf” plastic pedestals. The brownstoner roofs were not made for cheap inferior deck surfacings that are improperly engineered for drain-off from under them. Blockage from build-up of plant-dirt, leaves,and frozen snow will eat into the rubber roofing membrane and cause deterioration.–leaks. It pays to hire a professional builder. There is no such thing as a cheap deck just like there is no such thing as a cheap car. Better safe than sorry.
