Company to fabricate posts and rail for stoop?
We are redoing our facade and would like to also replace the thin railing on our front steps with newel posts and rails that match the original. I assume we need to find someone to fabricate this. Probably in aluminum. Anyone already been through this and have tips? Any recs on companies? Thanks in advance
lindaaponte
30
yudashasom | 4 years and 6 months ago
object(WP_User)#5048 (8) {
  object(stdClass)#5035 (12) {
Most replicas/reproduction are aluminum . When painted you won’t know the difference
lindaaponte | 4 years and 6 months ago
object(WP_User)#5047 (8) {
  object(stdClass)#5046 (12) {
    string(6) "209557"
    string(11) "lindaaponte"
    string(34) "$P$BXw.8UZMrN75Kjebm6L0F015rn2ev.."
    string(20) "laponte631@gmail.com"
    string(19) "2024-07-03 12:21:24"
    string(45) "1720009285:$P$BLF6kjaVqhjNnw8GlX83C0G4hIgolS/"
    string(12) "linda aponte"
  int(209557)
Thanks Eman137! I saw this and was wondering if it was recommended.
string(6) "201692"
object(WP_User)#5240 (8) {
  object(stdClass)#5241 (12) {
    string(6) "209557"
  int(209557)
And I couldn’t do off the shelf anyway because has to be approved by the landmark preservation committee.
object(WP_User)#5243 (8) {
  object(stdClass)#5242 (12) {
    string(6) "209557"
  int(209557)
Yes they paint it black. These are fabricators who do both iron and aluminum. Not off the shelf. I’ve looked on the forum for recs but some of the ones I found are from old convos and it looks like the companies are not even around.
cate | 4 years and 6 months ago
object(WP_User)#5241 (8) {
  object(stdClass)#5048 (12) {
Do they paint the aluminum black? I’ve never heard of using aluminum (unless you mean the off the shelf modern aluminum rails you see all over Sunset Park). There are many cast iron fabricators in Brooklyn whose speciality is casting these railings from historical examples. Search the Forum for their names.
  object(stdClass)#5248 (12) {
    string(6) "209557"
  int(209557)
Thank you.
JohnHancock | 4 years and 6 months ago
object(WP_User)#5242 (8) {
  object(stdClass)#5244 (12) {
    string(5) "22067"
    string(11) "JohnHancock"
  int(22067)
NY iron underneath the Subway bridge on 9th street at the far end of the Lowe’s parking lot. It’s a big outside yard filled with salvage
object(WP_User)#5248 (8) {
    string(6) "209557"
  int(209557)
Yeah we had some companies come by and at least two recommended aluminum if they have to fabricate it. I saw on brownstoner someone had recommended aluminum too if we have them made – one noted it doesn’t rust like iron. I had assumed iron initially also. We were going to look at salvage yards but we have to match our originals because our home is in historic district. Wasn’t sure if we could fine two newel posts etc to closely match the original. What salvage shops do you recommend?
colonialrevival | 4 years and 6 months ago
  object(stdClass)#5249 (12) {
    string(6) "195334"
    string(15) "colonialrevival"
  int(195334)
Aluminum? You’re looking for cast iron. I’d recommend checking out some architectural salvage shops as well — you may find that you don’t need a fabricator, just an ironworker to come install in-situ.
