Clogged kitchen sink - recommendations?
Can anyone recommend a plumber or other service to unclog a kitchen sink?
We had Roto Rooter stop by, and their estimate (~$700 or so) seems crazy. A few other companies want to charge (around $100) to show up and give a quote, which seems like a waste.
Thanks.
ib28
17
object(WP_User)#4969 (8) {
  object(stdClass)#4981 (12) {
Putting a drain auger in my kitchen sink drain would make me nervous. A commercial drain ok, but not these thin brass lines. A lot of these brass lines are already worn thin from all the acidic foods and stuff we put down them.
  object(stdClass)#5238 (12) {
bobjbkln, Nope, no overflows. The tub actually has a brass cap over the opening where the overflow opening would go. [Tub Brass Cap](//muut.com/u/brownstoner/s2/:brownstoner:JNLA:tubbrasscap.jpg.jpg)
colonialrevival | 3 years and 3 months ago
object(WP_User)#5002 (8) {
  object(stdClass)#4999 (12) {
    string(6) "195334"
    string(15) "colonialrevival"
  int(195334)
Ryobi 18v power auger is $150 from home depot.
shahnandersen
object(WP_User)#141095 (8) {
  object(stdClass)#5241 (12) {
    string(1) "6"
    string(13) "shahnandersen"
  int(6)
@Bob Marvin,
I would guess that both your bathroom sink and tub have a vent/overflow. On the sink do you have a part like in the picture, that is used like a stopper to allow the sink to fill? If so, that part also acts as a vent/overflow . You might have something similar outside your tub for taking a bath. Same principle. They have holes near the top of the tube that acts as overflows. [P1010455](//muut.com/u/brownstoner/s2/:brownstoner:KrDM:p1010455.jpg.jpg)
string(6) "202751"
Electric Sewer & Drain Service (718) 863-7144 is cheaper. Roebic drain cleaning products are cheaper still https://www.roebic.com/drain-openers.shtml
nyc_sport | 3 years and 3 months ago
object(WP_User)#141087 (8) {
  object(stdClass)#141086 (12) {
    string(5) "39535"
    string(9) "nyc_sport"
    string(16) "btfraw@yahoo.com"
  int(39535)
And put duck tape over the bathroom sink overflow hole before plunging . . .
lkrshacmzcy | 3 years and 3 months ago
object(WP_User)#141085 (8) {
  object(stdClass)#141084 (12) {
    string(6) "209518"
    string(11) "lkrshacmzcy"
  int(209518)
If you call a Drain Cleaning company, you will get it for cheaper.
If you call a Plumbing Company, which it seems like were the companies you called, the cost will be higher.
object(WP_User)#141088 (8) {
  object(stdClass)#141078 (12) {
    string(6) "209518"
  int(209518)
  object(stdClass)#141077 (12) {
Got ya. Also, neither my 1899 bathtub nor 1910 bathroom sink have overflows.
object(WP_User)#141081 (8) {
  object(stdClass)#141082 (12) {
Bob. I don’t ever recall an overflow in a kitchen sink.
  object(stdClass)#141076 (12) {
I guess you could cover the hole. After reading this I realized that my kitchen sink DOESN’T have an overflow. That surprised me because it’s only about five years old. My upstairs bathroom sink doesn’t have one either, but it’s salvaged from a c. 1910 house.
object(WP_User)#141080 (8) {
  object(stdClass)#141087 (12) {
I realize this is about a kitchen sink but people reading this should know plungers are a pain in the neck on bathroom sinks because of the overflow. It allows the pressure created by the plunger out. If you can
  object(stdClass)#141083 (12) {
Try a plunger first
  object(stdClass)#141090 (12) {
Some traps do not have a cleanout. Go to home depot and get a mini drain auger. Cheap plastic thing you can push down there. We keep a few here.
object(WP_User)#141083 (8) {
See what john hancock says. That is it right there. Do not do it before eating.
Also, i always remember my father getting mad at me for putting grease down the drain because it would clog the line. Not only that but one time asca young adult i poured grease down the drain without running any water behind it. The grease settled in the trap and hardened on top of the water in the trap. I went to run water & no go. I used a heat gun to heat the clog and it cleared and i flushed it out with hot water. Now if i pour grease down there i run piping hot water ahead of it and behind it.
JohnHancock | 3 years and 3 months ago
object(WP_User)#141090 (8) {
  object(stdClass)#141080 (12) {
    string(5) "22067"
    string(11) "JohnHancock"
  int(22067)
Put a bucket underneath, unscrew trap, run and twist auger( snake) put it back together, flush with hot water and repeat! Roto rooter is doing just that, for clogs in the main line you will need their service. Trust me, it’s not a terrible job but easy enough and could happen frequently so worth doing it yourself if you can!
cate | 3 years and 3 months ago
object(WP_User)#141082 (8) {
  object(stdClass)#141085 (12) {
Your best bet is to get a recommendation for a local plumber who specializes in drains and has been in business for years. I can’t recommend people because I work for Brownstoner, but others here can. Plumbers who specialize in drains typically charge a flat fee per drain to unclog a clog. We have in the past paid $350 or so for the first drain and $100 for each drain after that (I can’t remember exactly), but prices have gone up recently and probably start at $450 or so.
