Brownstone skylights and upper tenant drama
Actually, I wonder if it’s against firecode for a 2-family. I ask because we already have a fire hatch (separate of the two skylights). The two skylights are fixed…
emmajacob
in General Discussion 8 years and 3 months ago
23
BKALLDAY | 8 years and 3 months ago
object(WP_User)#5029 (8) {
object(stdClass)#5017 (12) {
string(4) "6172"
string(8) "BKALLDAY"
string(8) "bkallday"
int(6172)
I know that some skylights if Pitched can serve as a “vented” skylight but Velux skylights are a different story. At the end of the day you installed a solution that works. If you have to water proof a bit better then call the installer and have no more conversations with the tenant about the path you took. It’s done.
empathie00 | 8 years and 3 months ago
object(WP_User)#5028 (8) {
object(stdClass)#5027 (12) {
string(6) "177582"
string(10) "empathie00"
int(177582)
daveinbedstuy – true, but then again, it should be against energy code to have your house sucking out all its heat and having wind on your top floor – right? So, I choose energy efficiency. 😉
daveinbedstuy | 8 years and 3 months ago
object(WP_User)#5024 (8) {
object(stdClass)#5030 (12) {
I did too.
