Boiler Replacement Cost
We need to replace our boiler and received a general quote of $12K-$14K. Is this consistent with what other people have paid?
jazzwalk
cate | 5 years ago
object(WP_User)#4992 (8) {
object(stdClass)#5004 (12) {
For that price, you should be able to convert from oil to gas, if that is still feasible these days.
Master Plvmber | 5 years ago
object(WP_User)#4994 (8) {
object(stdClass)#4991 (12) {
Yes. Boiler replacements, done well, cost a big number. Many are installed poorly and cost more in maintenance and operating costs.
greenworks | 5 years ago
object(WP_User)#4993 (8) {
string(6) "193898"
string(10) "greenworks"
int(193898)
Yikes! We occasionally think about replacing our ancient boiler that conservatively dates from the 1940’s and is the size of a Volkswagen but those numbers are scary.
That’s the Cost of doing things properly I guess.
lkrshacmzcy | 5 years ago
object(stdClass)#4989 (12) {
string(6) "209518"
string(11) "lkrshacmzcy"
int(209518)
Boiler Replacement costs are very spread out. I have seen some “companies” do a cut and swap for as little as 6K; but those are the boilers that usually have issues in the same season and the “company” no longer responds.
For a full permitted Boiler Replacement and control/piping upgrade I would say that is pretty standard; though if you need upgrades for inspection purposes that can really start to climb.
object(stdClass)#4988 (12) {
string(6) "209518"
int(209518)
Guest User | 5 years ago
Eman would know best. I had my combi installed for slightly less. However I purchased the unit. However when I was getting quotes they all said that if I had more zones this naturally would increase the cost. I had multiple zones.
sounds about right especially if they are redoing the near piping
