Best practice for restoring wood trim before painting
We have a lot of wood trim and wainscoting (see picture) that has been buried under many years of paint. Since we don’t quite have the budget to strip it down to the wood and then repaint, which I imagine is what you’re really “supposed” to do, what’s the next best procedure for getting the wood in good enough shape to paint -and look good enough?
The more specific info the better – what methods and products would you use? Is there anything to avoid that might damage the wood? and if you know anyone who could do this project, that’d be great too!
[Wainscoting](//muut.com/u/brownstoner/s3/:brownstoner:x4Vz:wainscoting.jpg.jpg)
28
string(6) "200737"
Thanks @cate and @stevecym for the detailed answer! @Steve – So to make sure I understand you correctly, when sanding the old non latex paint that might contain lead (I will test first), the best procedure is to wet a regular piece of sandpaper?
And any recs for the finish for the paint – semigloss? Or maybe if it’s not going to look “perfect” we should choose something less glossy so as not to draw the eye to much to the trim?
cate | 4 years and 11 months ago
object(WP_User)#5010 (8) {
  object(stdClass)#5008 (12) {
You could potentially make a mess and get lead paint dust everywhere if you don’t properly prepare the area and know what you are doing.
stevecym | 4 years and 11 months ago
object(WP_User)#5026 (8) {
  object(stdClass)#5242 (12) {
And you are not really sanding to remove paint but smooth it over a bit. Take down brush marks, debris left by previous efforts.
And use a good brush for final coat.
object(WP_User)#5027 (8) {
  object(stdClass)#5019 (12) {
And follow the directions on the paint cans. If you read and follow those directions, you will be a better skilled painter than 90% of the painters in this city.
  object(stdClass)#5034 (12) {
Do not use sanding sponges. They travel over the imperfections and work harder on the surrounding areas. Before final coats, i will scuff sand with a 220 sponge.
object(WP_User)#5019 (8) {
  object(stdClass)#5026 (12) {
Use a wet dry sand paper where wet sanding.
object(WP_User)#5034 (8) {
  object(stdClass)#5027 (12) {
There is no reason to strip. Sand first. Choosing a grit might be tricky depending on how soft the top coat is. Too rough you move it around and remove more than you need. To fine it does nothing. When i start something like this i have 60, 80, 100, 120, and 150 grit on hand. You have to make a decision, do you want to sand that latex off and hit the lead paint and send that around the house. No you dont. If you sand the old paint, spray it with water. If you choose to leave most of the paint, sand the rough edges down, perhaps with 100 grit. Wet any of the old paint. And test all this for lead. Then, go over all with 120 and 150. Dust it off and prime with zinser bin. Coat with latex. Let dry well. Fill any rough spots with latex spackle. Tint the spackle a little so the patches show. Sand patches by hand with a flat wood block and 150 grit. Dust. Prime. Paint all. Repeat as nec. Sand with 180. Dust. Caulk. Paint. Caulk is done after all sanding. Before last coat.
  object(stdClass)#5010 (12) {
Generally speaking, you’d remove any stray hardware, repair any broken woodwork, caulk as needed, prime and paint. Looks like you’re missing a crown molding. A finish carpenter could fix that — preferably one with old house experience. Don’t sand paint that might contain lead.
