BATHROOM VENTILATION
Looking for advise on how best to retrofit ceiling ventilation fan in the bathrooms of a 4 unit brownstone. Can the vent connect to pre-existing vents that go to the roof or will it require removal of bricks to the outside wall?
briskey
in General Discussion 7 years and 11 months ago
smadargolan | 7 years and 11 months ago
object(WP_User)#4999 (8) {
object(stdClass)#5024 (12) {
string(6) "193101"
string(11) "smadargolan"
string(34) "$P$Bvlyvz3wGsuOm2N3WBgm81r0gInnBy0"
string(24) "locksmithfl.us@gmail.com"
string(19) "2024-02-23 10:37:06"
int(193101)
Do you mean the main stack? If so, you don’t want that – that’s full of sewer gas (which the p-traps on all the plumbing fixtures keep out). Also, if you’re connecting more than one fan to the same duct/vent line, I would think turning one on would actually potentially push air back into the other(s). If you mean a chimney flue, like Randolph said, be careful that you’re not using the same one that vents the boiler or HWH – you’d get CO coming back in that way. Also, I’m just hypothesizing, but if a bathroom vent is meant to remove steam, that would mean a lot of moisture in the flue which could be bad, unless you’re lining it with metal ductwork.
Is there an airshaft or light well? That’s how I ran mine to the roof – up along the inside of the light well.
eileengray | 7 years and 11 months ago
object(WP_User)#5000 (8) {
object(stdClass)#5001 (12) {
string(6) "185785"
string(10) "eileengray"
int(185785)
If you are going to an outside wall, check the code restrictions that prohibit bathroom exhaust openings near windows. In most brownstones it is hard to get a legal vent on an outside wall.
randolph | 7 years and 11 months ago
object(WP_User)#5004 (8) {
object(stdClass)#4998 (12) {
string(5) "26171"
string(8) "randolph"
int(26171)
you certainly do not want to tap into a boiler or hot water heater or furnace vent.
