Are IKEA sinks/vanities to NY code?
We are planning on having IKEA sinks and vanities in 2 of our bathrooms… The sinks come with PVC traps that fit nicely into the vanities, however I just saw on an online forum that PVC pipes/traps are not to code in NYC. So I guess we can’t use them??
Seems insane that IKEA would be selling stuff that is not to code.
Anyone have any experience/advice?
Guest User | 5 years and 6 months ago
cate | 5 years and 6 months ago
object(WP_User)#5038 (8) {
object(stdClass)#5026 (12) {
I believe the code has changed in the last five years. Just ask your licensed plumber. If you are doing this work as part of a larger Alt-1 or Alt-2 renovation, the city may need to inspect and sign off in which case it could be an issue. If you’re just replacing a sink, it’s probably not a big concern.
from what I can find the code that is most current, 2014, anything below 5 stories is fine for PVC
https://up.codes/viewer/new_york_city/nyc-plumbing-code-2014/chapter/7/sanitary-drainage#701.10
@Cate I’ve been trying to verify what you wrote but have not found anything about this. Any ideas of where to look to find the answer?
object(WP_User)#5043 (8) {
object(stdClass)#5042 (12) {
I vaguely recall hearing that PVC for drains was disallowed in one- and two-family homes in NYC a few years ago — might have been about 2015 or so. (Of course anything you already have is grandfathered in.)
Also found this article from 2003 that says plastic pipe is OK in up to 2 family homes… Wondering if this is still the case?
https://www.pmmag.com/articles/86706-ny-enforces-restriction-on-plastic-pipe
Quote:
Article 10-A of New York’s labor law states that plastic pipe, including ABS and PVC, can only be used in sanitary drainage piping of one- and two-family homes or “multiple dwellings” of six stories or less. All other buildings must use copper, cast-iron, wrought iron, galvanized steel, or other approved piping materials. CPVC, PEX and PEX-AL-PEX also can be used in the water distribution piping for single- and two-family homes.
correction: the trap is made of polypropylene not PVC.
greenworks | 5 years and 6 months ago
object(WP_User)#5008 (8) {
object(stdClass)#5005 (12) {
string(6) "193898"
string(10) "greenworks"
int(193898)
It may or may not be up to code but in the past almost everyone I know has utilized either ikea traps or pvc traps, including us.
If the potential for a minor code violation will keep you up at night, dig deeper to find out for sure and act accordingly. Otherwise I wouldn’t worry. My only issue is that I generally don’t like pvc anything for most plumbing bc of the noise.
