Architect Recco - Narrowish townhome
Hi there! We are in the process of closing on a wood frame townhouse that will measure 16.67 x 40. We will live in the upper triplex and rent the garden unit.
The plan is to remove as many walls as possible and open up the parlor to be the kitchen/dining/living room. Looking for recommended architect / designer to help maximize the space and make it feel open. Any ideas?
Thanks!!
brassman
in General Discussion 6 years and 10 months ago
SoSlope | 6 years and 10 months ago
object(WP_User)#5062 (8) {
  object(stdClass)#5115 (12) {
    string(5) "16781"
    string(7) "SoSlope"
    string(7) "SoSlope"
    string(7) "SoSlope"
  int(16781)
Aniket Shahane (https://www.oa-ny.com/). His personal home is a lot narrower than yours. I strongly endorse his work.
Also, I agree with Cate (if I understand her correctly). Inside the front door, you probably have a staircase and a narrow hallway with a wall separating the living room from that hallway. If you open up that wall dramatically (basically remove it, although you can keep a large arched frame), the living room feels far larger. 16.67′ is not actually that narrow and does not need to feel narrow at all.
cate | 6 years and 10 months ago
object(WP_User)#5063 (8) {
  object(stdClass)#5064 (12) {
If it’s an old house with details, you can greatly enlarge the opening to the hall and to the next room, and it will offer the same functionality and actually make the space appear larger than if you removed the walls completely, IMHO. Adding a window seat along the front wall is attractive and functional. Keep the entry vestibule to optimize privacy, noise, temperature. Scroll through a ton of Insiders https://www.brownstoner.com/the-insider/ and google “narrow” and “Brownstoner” for a wide range of ideas for narrow spaces. Good luck.
AnArchitect | 6 years and 10 months ago
object(WP_User)#5061 (8) {
  object(stdClass)#5060 (12) {
    string(5) "89402"
    string(11) "AnArchitect"
    string(34) "$P$B1nP7yyKJcLDOOq69fypmL4oqEIQUM."
    string(11) "anarchitect"
    string(24) "acortes@agenciegroup.com"
    string(26) "/forums/users/anarchitect/"
    string(19) "2017-08-10 14:36:11"
  int(89402)
Hi. We have worked on many townhouses, some of them frame structures, including a 16.67 x 35′ home. I’d be happy to share our experiences and throw our hat in the ring for consideration: www.agenciegroup.com / 212-203-0265 – Best
Guest User | 6 years and 10 months ago
string(6) "199384"
We’re currently working with Sean Gold of Studio nForm and he’s been an absolute pleasure throughout. http://studionform.com
