Adding a floor on roof
Brooklyn yes, but actually not a row house per se. I am fully detached brick. Im sure the sip guys have data sheets they couldn’t have gotten their ICC fire and structural ratings without testing.
sew536
35
workisfun | 8 years and 10 months ago
object(WP_User)#5247 (8) {
  object(stdClass)#5075 (12) {
    string(6) "184143"
    string(9) "workisfun"
  int(184143)
By the way, there was no need to slight a hard working Mexican. Your point can be made without disparaging a whole nationality.
sew536 | 8 years and 10 months ago
object(WP_User)#5246 (8) {
  object(stdClass)#5245 (12) {
    string(6) "193217"
    string(6) "sew536"
    string(34) "$P$B5CH1YnP7uEfm2TApmQMZHaeUBCk8x."
    string(6) "sew536"
    string(20) "weeksskeew@gmail.com"
    string(19) "2024-02-23 10:40:23"
    string(23) "Sarah Weeks Sarah Weeks"
  int(193217)
@ work
Thanks for the morality tip but i can work out my own values thanks. I worked in the sleight on purpose, you see I have a problem with them coming here illegally and doing inferior work for wages I can’t compete with if if I don’t want to live like a peon. But I really really hate my co nationals that hire them and defend the problem.
object(WP_User)#5243 (8) {
  object(stdClass)#5248 (12) {
    string(6) "193217"
    string(6) "sew536"
    string(6) "sew536"
  int(193217)
@ work
object(WP_User)#5245 (8) {
  object(stdClass)#5247 (12) {
    string(6) "193217"
    string(6) "sew536"
    string(6) "sew536"
  int(193217)
@ work
daveinbedstuy | 8 years and 10 months ago
object(WP_User)#5248 (8) {
  object(stdClass)#5246 (12) {
If they are doing inferior work, how are they getting wages you can’t compete with?
  object(stdClass)#5243 (12) {
    string(6) "184143"
  int(184143)
What makes you so confident you “can work out your own values”? When you dismiss my non-judgemental feedback as a “morality tip” in a sarcastic punchline, it seems you might need a little help understanding why you use your own discontent as reason to make absurd generalizations. The topics of labor practices and immigration are valid for discussion, but your unproductive and offensive generalizations contribute to the animosity, and continuation of unsolved policy, that is preventing this country from realizing just, humane, and progressive policies. I don’t know… some people just prefer anger to solutions.
Arkady | 8 years and 10 months ago
  object(stdClass)#5249 (12) {
Totally gratuitous slur complete w/ ignorant misspelling that matches the ignorant stance.
jimhillra | 8 years and 10 months ago
    string(6) "180609"
    string(9) "jimhillra"
  int(180609)
Going back to the original subject matter, the question is not whether or not the SIPs have fire rating, or whether they are ICC approved. NYC building code supersedes ICC, and it requires that exterior bearing walls within Fire Districts (all of Brooklyn, Manhattan, and Bronx, and much of Staten Island and Queens) be non-combustible. Non-combustible is not the same as fire rated. Wood framing can be fire rated, but is till combustible. It’s been a while since I looked into SIPs, so I was unaware that they make them with cement board.
  object(stdClass)#5250 (12) {
And the real issue is whether it’s code.
  object(stdClass)#5251 (12) {
    string(6) "193217"
    string(6) "sew536"
    string(6) "sew536"
  int(193217)
The code is ICC and what they have added to the icc in some areas, I dont think your non combustible always applies but i think in my case three family 4 floors it would, I also think it only applies to the roof of the addition not the walls. but Im only a handy guy not a archetect and havnt actually researched this yet, I have been a heavy construction forman for 35 years in nyc and been a contrator outside nyc so i have some familiarity with parts of the various codes.
These are not simply fire rated, their fire rating is they are zero combustible, a metal stud with two 5/8 inside and the 1-1 /4 shaft wall outside and 6″ mineral wool between that you suggest and i see all over is only a two hour rating.
object(WP_User)#5250 (8) {
    string(6) "193217"
    string(6) "sew536"
    string(6) "sew536"
  int(193217)
object(WP_User)#5251 (8) {
    string(6) "193217"
    string(6) "sew536"
    string(6) "sew536"
  int(193217)
    string(6) "180609"
  int(180609)
We’re still talking a rowhouse in Brooklyn, right? If so, I can guarantee you that the side walls need to be non-combustible. No exception. The roof itself may or may not depending upon a number of things, but most likely not. If the SIP manufacturer says they are zero combustible, it may be that the DOB will accept that outright, or you could have to prove it to them by submitting the manufacturer’s data sheets.
    string(6) "193217"
    string(6) "sew536"
    string(6) "sew536"
  int(193217)
    string(6) "193217"
    string(6) "sew536"
    string(6) "sew536"
  int(193217)
