Looking for budget friendly designer or architect
We have a 15 ft wide apartment on the bottom 2 floors of our house.  We need someone who can coordinate and design the renovation, which is mostly going to be taking down a few walls, adding a bathroom and closets and redoing the lighting.  Not sure if we need an architect, and have a budget of around 60k.  Would consider a design/build firm or a recommendation for a good designer who can work with a contractor (we already have a few recommendations but would love some more!).  Anyone who specializes in green/sustainable construction a plus. Thanks!
bkmn
in Environmental and Green Design 14 years ago
pacificist | 14 years ago
object(WP_User)#5216 (8) {
  object(stdClass)#5192 (12) {
    string(5) "39263"
    string(10) "pacificist"
    string(26) "joannegraney@earthlink.net"
    string(25) "/forums/users/pacificist/"
    string(19) "2017-08-10 13:50:21"
  int(39263)
Did you happen to read The Insider a couple of weeks ago? The architect for that project was found through a design/construction referral service called The Sweeten. I thought it was an interesting business model and might be worth looking into for your situation. http://thesweeten.com/ Good luck!
jigman | 14 years ago
object(WP_User)#5215 (8) {
  object(stdClass)#5214 (12) {
    string(4) "2252"
    string(6) "jigman"
    string(34) "$P$BVgKeMXtVvqNS5DC1ooS13nguQV2qu."
    string(6) "jigman"
    string(17) "mmueller@pbdw.com"
    string(50) "http://www.brownstoner.com/forums/users/arch_tect/"
    string(6) "jigman"
  int(2252)
Ron Baker of Baker Design Build should fit your needs well. http://bakerdesign-build.com/
prospectpark | 14 years ago
object(WP_User)#5165 (8) {
  object(stdClass)#5217 (12) {
    string(5) "62537"
    string(12) "prospectpark"
    string(34) "$P$B1a3z6YdTE37XjGaz0vxhhvCjVZT7M."
    string(19) "danebklyn@yahoo.com"
    string(24) "/forums/users/danebklyn/"
    string(19) "2017-08-10 14:21:46"
  int(62537)
Hi,
Gerald La Starza of Brooklyn Modern designed our bathroom and cabinets. You can reach him at gerald@brooklynmodern.com If you’re adding a bathroom, you probably need to file the job and get the plans stamped by an architect or licensed plumber. A design build firm can also handle that type of work for less and sub out the stamping if it’s a simple project. -D
