fireplace: to open or not to open...
I am SO sorry for the very late reply. Cate: Thank you thank you thank you for posting all the links and photos. It is hugely helpful and I am better understanding what the potential is. I LOVE the mantel you found at Build it Green. And that kind of price is totally doable for something that really makes a statement. I’ve posted another photo of the mantel in what will be the very small kid’s bedroom. I think the shelves are wood, but I’ll have to take another look. I am totally convinced now after reading everyone’s posts that we should not remove the fireplaces at all and instead open them up, see what we have, and either install a new mantle or rehab what’s there. We actually have 6 fireplaces in the house – one in each of the front rooms and one in each of the backrooms. It’s tempting to open them all up! I’m thinking maybe we can put our bed in front of our bedroom’s fireplace, but will have to see if the head of a queen sized bed will fit nicely there. (we’re going to have closets flank each side of that fireplace) As for the tin ceilings – we won’t be doing down lights – I actually don’t like those so much, and my husband prefers using lamps anyway. So we’ll just use a single light fixture in the center of each room, w/ some island lighting in the kitchen. Now I just have to make sure our contractor is on board with this! williamsburgguys: love your tin ceilings. I can’t tell which is new vs original – kudos! 🙂
ps158
in Chimney and Fireplace 11 years and 6 months ago
32
cate | 11 years and 6 months ago
object(WP_User)#5092 (8) {
object(stdClass)#5080 (12) {
Here is a link to a photo of a kitchen in Clinton Hill. There is a 36-inch (circa 1950) Chambers range sitting in the open fireplace on the slate hearth. The back of the firebox is natural brick. Everything else has been plastered (or painted). Incidentally, if you look under the sink to the right you will see the original bead board that originally covered the walls. . http://www.pinterest.com/pin/149181806376185406/
object(WP_User)#5090 (8) {
object(stdClass)#5253 (12) {
Here’s a photo of a stove (not a range) sitting in a fireplace (plastered). This is from a house museum and is a re-creation so don’t take it too seriously but it gives you an idea of what some of the stoves looked like. I bet this was more typical of a tenement apartment. Across the way from us a tenement burned down in a fire many years ago but on the chimney wall of the house next door still remain all the mantel shelves from all the apartments. They are black iron shelves with fancy black iron brackets with a scroll design.
object(WP_User)#5091 (8) {
object(stdClass)#5254 (12) {
You can find lots of examples of painted mantels in the book “English Decoration” by Ben Pentreath. (It’s a wonderful book.) I can’t find the exact example I was thinking of but his website should give you an idea. Here’s a thread with lots of painted mantels although because they are English they are much older — these are 1780-1830s, I think. . http://www.benpentreath.com/interiors/projects/dorset/
object(WP_User)#5253 (8) {
object(stdClass)#5092 (12) {
If your mantel is slate, not wood, and you strip it, be advised you will expose the original stone (not the original faux painting) and some of the slate may be mismatched colors of blue, green, etc. Still very pretty. Just depends on what look you want. Also it’s much easier just to paint!
object(WP_User)#5254 (8) {
object(stdClass)#5090 (12) {
As for the electrical, you can save the tin ceilings if you aren’t too demanding about the light fixtures you are installing. In the case of our kitchen, we weren’t putting in downlights or anything like that — just three holes and boxes for regular fixtures. How they ever got boxes in there without disturbing the tin, I don’t know, but they did a great job. It’s extremely important to know where you want the lights, because once you make a hole, you can’t change it. (Except by patching, which would be obvious.) The location of beams could also prove an obstacle. If, for instance, there is a beam exactly where you want a fixture, it might not be feasible to cut out a bit (not that you would to anyway) since the tin will be in the way. However, this is easily worked around. In the case of a hanging fixture over a kitchen table, for example, you could located the box just to the side, then loop the fixture on a cord from a hook in the beam exactly where you want it (hope this makes sense). Your parlor floor should have medallions over old gas jets where the overhead lights should be, but sounds like it doesn’t? Also you don’t strictly need overhead lights in a living room — sconces and lamps could do the job. With our electricians, we typed up specific directions about what we wanted, and marked the location of all plugs with crosses made of blue painter’s tape. They don’t need to break open ceilings to run wires — they do it through the walls — unless, do you have elaborate plaster moldings on the upper cornice/cove/top of the wall area?
rh | 11 years and 6 months ago
object(stdClass)#5091 (12) {
string(4) "3878"
string(2) "rh"
string(2) "rh"
string(2) "rh"
int(3878)
Resident2, nobody is talking about reproduction “details”. You can totally replace details with period salvage that probably came from a house right down the block. I agree that you don’t buy a historic home only to strip it of it’s charm, but if it’s gone, Home Depot isn’t your only option. Plus, there’s no harm in carefully removing and replacing the same detail.
no-permits | 11 years and 6 months ago
string(6) "176811"
string(10) "no-permits"
string(16) "c90027@gmail.com"
int(176811)
i could be wrong, but I always thought tin was not original to these houses. thought it was added later for fire code when converted to multiple dwellings. regardless, it’s old and is nice. you shouldn’t mess with it much. electric can be snaked through very very easily. it’s done all the time around fragile plaster molding and medallions. your contract is either lazy or has no care for historical preservation. @resident2 agree with you. we are stewards of these buildings for future generations. other people put too much of their own “mark” on these places.
object(stdClass)#5256 (12) {
Sometimes the tin is original, sometimes not. Depends on the house and the period. It was very big circa 1890-1920.
object(stdClass)#5255 (12) {
Here’s a post about replacing our mantel which shows what a faux painted slate mantel might have looked like. There are two — scroll down to the last photo to see the one in original condition with its summer cover intact. Behind that is a space with walls and back made of brick. There may have originally been an insert in here to hold coal; it was never for a wood fire. These slate fireplaces did not have tile surrounds, and the hearths were usually slate as well. http://brownstoner.staging.wpengine.com/blog/2012/11/photo-pool-challenge-replacing-a-mantle/ Here’s another post, about the Crown Heights house tour, with fireplaces galore. The fourth photo down shows a totally original fireplace complete with its original and still working gas insert. (There’s also a kitchen with a built-in range; the tile behind it on the wall is new.) http://brownstoner.staging.wpengine.com/blog/2013/10/inside-crown-heights-historic-homes/
object(WP_User)#5256 (8) {
If you could post another photo of the mantel with the shelves above it, I would love to get a better look. If you resize the photo to small or medium, it will upload better. Also curious how old you think your house is and what area you are in? (Because that could tell us something about the age of the house.)
williamsburgguys | 11 years and 6 months ago
object(WP_User)#5255 (8) {
string(6) "179772"
string(16) "williamsburgguys"
string(34) "$P$BcTw5wsxim9sw6gnCR/OE1x0rr8VYR0"
string(26) "thomas.hellmer@verizon.net"
int(179772)
Love love love those builtins. I see your fireplace is still recessed somewhat – probably enough to clear the chimney hole to prevent soot and stuff from falling constantly when the wind blows. You wouldn’t gain much by removing the metal wall. I think ours is maybe 12-14″ deep in total. Those old Brickset ranges were really shallow and mostly just fit the hole for the smoke to go out. I do love them for their antique factor, however not something to fire up for a quick pizza 🙂 How times have changed. When we were redoing the back yard and tilling, raking, and getting ready to seed, we had to remove bag after bag of old coal cinders that were buried just under the top layer. Apparently back in the day our previous owners chose to dump their coal ash in the back yard rather than set it out for the ashman.
brucef | 11 years and 6 months ago
string(4) "4724"
string(6) "brucef"
string(6) "brucef"
string(6) "brucef"
int(4724)
Well, The prevailing sentiment from the above comments centers on the desirability of keeping fireplaces/tin trim. Many of the houses now being renovated are of post Civil War vintage, or in BedStuy much later 1890s on. Many of the homes in the earlier neighborhoods (closer to East River) are from earlier periods, the initial row house speculation and sub-divisions of farms 1830-1850’s. For these homes, tin was installed to meet early multiple dwelling fire codes. But back to the question in OP, regarding removal of flues to possibly regain space. I can share some experience in that regard, which has been prompted by the requirement for most new high efficiency gas boilers, namely that existing masonry flues must now be lined with flexible metal liners. Working backwards, replacement of an inefficient oil fired heating system leads obviously to a gas boiler, then trigger the flue liner requirement, which results in a formula that determines the liner dimensions required by the selected gas appliances. Next question is can a liner of that size be drawn down the existing masonry flue? We keep a selection of drawing caps, that we pull down with rope to determine if the liner will fit past unseen obstacles etc. So what to do if the liner won’t fit? if necessary, the flue has to come out if you are backed into a corner not literally) Modern approved B-Vent has zero clearance requirements, as long as it to non-flammable (metal stud box with drywall). Bear in mind that the hearth usually has no back course of brick. There have been previous threads regarding smoke from a neighbor’s house etc. What does that mean “has no back course of brick”???? That means that the party wall (usually two bricks thick) is only one brick thick in the back of your fireplace. In other words that one course of brick (that belongs to your neighbor, not you) is all that separates you from his living space. Scary, but true. So, there are quite a few complications that come with removing flues. 1\. There will a big hole where the flue used to be. 2\. There probably be a big hole where the hearth used to be (boxed out with mortised joists), but once the brick arch falls down, there is another big hole that needs to be framed, and new sub-floor. 3\. You need to install heavy angle bridging the flue, to support the new 2nd row of bricks that have to be installed where there’s none in back of flue (see scary reference above) 4\. Huge mess – we’re talking about tons of brick and old mortar. Nothing that confident adventurers should fear, just lots of rough carpentry, demo, and patching. But you will recover a LOT of space. All the above assumes a brick house, I did notice that OP said wood frame house, but 98% of my experience is with masonry only walls. Good Luck, Bruce
