Adding a Shower to a half bath
I am considering adding a shower to a half bath. The Shower would extend into my kitchen, thereby making my Kitchen (over 80 sq feet) into a kitchenette (less than 80 sq feet). I am not concerned about the reduction in my kitchen size. The house was built around 1940 and is a legal two family. I will be using a licensed plumber for the plumbing work and may do the other work myself or hire someone. Would I have to file for any other permits? Would anyone have any suggestions or pionters? Thanks.
rhjmem
in Building Code 10 years and 7 months ago
lisawillams | 10 years and 3 months ago
object(WP_User)#5052 (8) {
object(stdClass)#5031 (12) {
string(6) "193333"
string(11) "lisawillams"
string(34) "$P$Bya3nxATJKhd67LchaXtSullJngSTa1"
string(26) "kristinecristine@gmail.com"
string(19) "2024-02-23 10:52:25"
int(193333)
You contractor will feed with you these informations at the time of signing of the contract or check the building codes, rules and regulations in your place.
greenmountain | 10 years and 7 months ago
object(WP_User)#5051 (8) {
object(stdClass)#5050 (12) {
string(5) "12939"
string(13) "greenmountain"
int(12939)
Your plumber will need to file a permit, as you are adding a fixture. If you were replacing a tub with a shower, it would probably be reported as Ordinary Plumbing. I built many of these and I recommend against a traditional two stage drain. It doesn’t matter if your pan is vinyl or lead. All the water should go down the drain directly, and never need to be recaptured by a pan (pan liner). To do this, you need a membrane system. The membrane immediately under the tile floor, will extend about six or seven feet up the walls, and can be extended all across the floor, so a curb is unnecessary. You can see examples of it on my website, but I am currently engaged in a large project and can not offer to do the work this year. Green Mountain Construction and Design
