Sprinkler System and Two family Dwelling
Good morning all, is a sprinkler system required by the DOB for a two family? Thanks in advance!
brooklynchic
in Brownstoner Renovation 13 years and 10 months ago
sescroggie | 13 years and 6 months ago
object(WP_User)#4982 (8) {
object(stdClass)#5052 (12) {
string(6) "178953"
string(10) "sescroggie"
string(34) "$P$BVYwFdbv4cw7btMerhKarKt/KBEK3m/"
string(20) "sescroggie@gmail.com"
string(51) "http://www.brownstoner.com/forums/users/sescroggie/"
string(19) "2017-08-10 14:37:10"
int(178953)
Hi – We are looking to do the same – move the top floor rental in a 3 story/2 family townhouse to the garden floor. In the end, was a sprinkler required for your job? We are getting mixed answers from the various architects that we are talking with. Thanks.
AnArchitect | 13 years and 9 months ago
object(WP_User)#4981 (8) {
object(stdClass)#4980 (12) {
string(5) "89402"
string(11) "AnArchitect"
string(34) "$P$B1nP7yyKJcLDOOq69fypmL4oqEIQUM."
string(11) "anarchitect"
string(24) "acortes@agenciegroup.com"
string(26) "/forums/users/anarchitect/"
string(19) "2017-08-10 14:36:11"
int(89402)
Its not a change of use/occupancy , then you’re filing an Alt 2? If so you should be ok w/o spk, but I’ll defer to your architect. Best luck.
AnArchitect | 13 years and 10 months ago
object(WP_User)#4977 (8) {
object(stdClass)#4983 (12) {
string(5) "89402"
int(89402)
If you are changing the CO you will likely have to add sprinkler unless you can prove the home used to be a 2 family at some point in its history. If the property is on a wide street then you meet a Fire Department exception which gives you better position with DoB on seeking a waiver to the requirement. You may also try to only sprinkler the tenant unit, which might be accomplished by pulling heads off the domestic and save you sme money. Best – www.agenciegroup.com
housepoor | 13 years and 10 months ago
object(stdClass)#4984 (12) {
string(5) "71781"
string(9) "housepoor"
int(71781)
While the OP didn’t say anything about reonvations on the building, I thought that if you are changing the use in any way — say going from a 3/4 family to a 2 family — then the DOB will require spinklers. Maybe some of the architects can chime in here?
stevecym | 13 years and 10 months ago
object(WP_User)#4983 (8) {
object(stdClass)#4981 (12) {
Not for a two family. Steve
