Intercom Reccs
I’m in the midst of a gut on a two fam. We’re in the upper and I’d like to install an intercom while the walls are open and running the wire is easy. Has anyone any recommendations about systems – just a bell and intercom, no door opener – or at the least, what kind of wire should be run?
Thanks.
flyingdesigner
in Architecture 14 years and 8 months ago
shahnandersen
object(WP_User)#141194 (8) {
object(stdClass)#4995 (12) {
string(1) "6"
string(13) "shahnandersen"
int(6)
The type of wiring will be depend on the system you choose. Some systems will only need 2 conductors, some 4, some 6\. It should all be riser rated and run away from any other electrical wiring. I would start by selecting your equipment. I would recommend Aiphone or Lee Dan. They’re common enough that parts are readily available any anyone can work on them. You may not want a door release now, but you or a future owner may, so it can’t hurt to run the wire for it. One advantage of putting in a door strike is than it would be very simple to put in a standalone access system on the door so that you don’t need keys.
