kitchen renovations
Hi!!! Guys!! I was planning to renovate my kitchen!! Planning to add metal accent to it~ What do you feel? Hope this help me cut down a lot of cost!!
lisawillams
in About Brooklyn 10 years and 4 months ago
mrsupers | 10 years and 4 months ago
object(WP_User)#5311 (8) {
  object(stdClass)#5299 (12) {
    string(6) "194015"
    string(8) "mrsupers"
    string(34) "$P$B3fm/Pbc1qT8KgY/JEYUjXLHH8oe.a1"
    string(25) "mrsuperbrooklyn@gmail.com"
    string(19) "2024-02-23 12:57:00"
  int(194015)
Adding a metal accent is great choice..keep going.. All the best
rh | 10 years and 4 months ago
object(WP_User)#5310 (8) {
  object(stdClass)#5309 (12) {
    string(4) "3878"
    string(2) "rh"
    string(2) "rh"
    string(2) "rh"
  int(3878)
Oh wait…there’s an even easier way than pouring concrete! I did this feathered concrete counter nearly 3 years ago in a tenant’s apartment and it has held up perfectly. http://reclaimedhome.com/2013/02/07/diy-concrete-countertop/
kassie319 | 10 years and 4 months ago
object(WP_User)#5306 (8) {
  object(stdClass)#5312 (12) {
    string(6) "194226"
    string(9) "kassie319"
  int(194226)
BCB Stainless Steel in Bushwick do pretty decent work.
thetinkerswagon | 10 years and 4 months ago
  object(stdClass)#5313 (12) {
    string(5) "21531"
    string(15) "thetinkerswagon"
  int(21531)
down around the bowery are kitchen fabricating shops – for restaurants, etc. Steve
daveinbedstuy | 10 years and 4 months ago
  object(stdClass)#5314 (12) {
In Philadelphia, I had a beautiful stainless steel backsplash made with rolled edges. One of the shops that fabricate the food street carts made it. Not sure where those shops are in NYC. My guess is south Brooklyn and Queens. DIY concrete countertops are also a big moneysaver. Buld a frame. Use some metal stucco lathe backing as reinforcement and pour the concrete.
  object(stdClass)#5315 (12) {
    string(4) "3878"
    string(2) "rh"
    string(2) "rh"
    string(2) "rh"
  int(3878)
It’s expensive if you go to some high end place and have them install it for you, but you can buy sheets and DIY (although it does take some skill). That being said, Xagor makes a nice point. I’ve been known to use metal tin ceiling as a backsplash. You can find it anywhere, old or new, and it’s an easy install.
espeon | 10 years and 4 months ago
  object(stdClass)#5316 (12) {
    string(6) "193699"
    string(6) "espeon"
    string(34) "$P$BZyx2mM005Jq.ONsUfxGgqC2r92vM10"
    string(6) "espeon"
    string(35) "hannibalthecannibal2046@hotmail.com"
    string(19) "2024-02-23 11:20:43"
    string(21) "James Jing James Jing"
  int(193699)
The only metal accent I can think of that may save money is a stainless steel backsplash!!!
BobMarvin | 10 years and 4 months ago
object(WP_User)#5315 (8) {
  object(stdClass)#5310 (12) {
Zinc or copper are beautiful, but quite costly. The c. 1915 Hoosier cabinets I have in my kitchen have pull-out counters covered in sheet aluminum; I wonder how that would work for new counter tops? I wanted to try when we replaced the ’70s Formica in the rest of our kitchen, but was outvoted in favor of stone. FWIW one of our aluminum Hoosier counters is a 100 year old original; the other was a new replacement when we bought the cabinet >40 years ago. Both still look good, although the older one has considerable ‘patina’
object(WP_User)#5317 (8) {
  object(stdClass)#5318 (12) {
    string(4) "3878"
    string(2) "rh"
    string(2) "rh"
    string(2) "rh"
  int(3878)
Metal accent? Zinc or copper counters. That’s my 2 cents.
