Heating in 1-zone house only work on upstairs floors, not downstairs
We just bought a Brooklyn 2-family- house with a newish Williamson gas boiler and baseboard heaters in all the rooms. When I set the thermostat (located on the upper floor of the upstairs apartment), heat starts streaming through the upstairs heaters, but the downstairs baseboards of that same apartment stay cold — not a hint of warmth. The house has a rental on the ground floor, for which there is a second Williamson boiler and a separate thermostat, located in that garden apt. That system works well. Anybody has any idea what’s going on? Thank you.
michaelsaur67
in About Brooklyn 10 years and 6 months ago
13
steam_man | 10 years and 6 months ago
object(WP_User)#5320 (8) {
object(stdClass)#5307 (12) {
string(6) "176846"
string(9) "steam_man"
int(176846)
ummm… Gross.
daveinbedstuy | 10 years and 6 months ago
object(WP_User)#5319 (8) {
object(stdClass)#5318 (12) {
I got something here for you to drain, steam_man. 🙂
object(WP_User)#5314 (8) {
object(stdClass)#5321 (12) {
string(6) "176846"
int(176846)
Well done DiBS. You drained his boiler.
michaelsaur67 | 10 years and 6 months ago
object(stdClass)#5322 (12) {
string(6) "185202"
string(13) "michaelsaur67"
int(185202)
Bleeding the system solved the problem — lots of air. Warm now. Thank you very much for your thoughts and time.
object(WP_User)#5321 (8) {
object(stdClass)#5319 (12) {
string(6) "185202"
int(185202)
Hi, Thanks Daveinbedstuy and steam_man, yes, the red valves are drains. I keep them closed.
object(WP_User)#5322 (8) {
object(stdClass)#5314 (12) {
Sorry. From another pic, those are obviously drains. Don’t open the red valves. LOL
object(stdClass)#5320 (12) {
He said he has baseboards, not radiators. Yes, make sure both of the red valves are open. Obviously the other two lever ball valves are open (No reason for both of those valves in a row). Check further down the line to the first floor like I said above.
string(6) "176846"
int(176846)
I meant the valves before and after the radiators. Are they open? Also, those red handle valve look suspicious because they exist in the same line as the ball valves below them. I can’t tell you what should happen with them because I can’t see the piping they are serving and what it does. The one on the left looks like a bypass but I’m not sure. So if you know what the piping scheme is there, check the red valves, at least one, possibly both should be open. DON’T mess with them if you don’t know what they serve!
I can only think that there is another valve along the feed to the downstairs baseboards or there is a thermostat valve in that line that is closed/not connected
string(6) "185202"
int(185202)
Hi eman134, These are the pictures of the boiler setup. I hope that helps. Thanks!
eman134 | 10 years and 6 months ago
Put up a photo of the boiler setup so that I can see it’s layout
string(6) "185202"
int(185202)
The yellow valves at the boiler? Both are open.
object(stdClass)#5323 (12) {
string(6) "176846"
int(176846)
Are the valves open?
