bathtub not draining in first floor brownstone
Hi: My bathtub on first floor not draining when I shower. Need plumber or someone who can fix it. thanks terry
terryhoppy
in About Brooklyn 10 years and 6 months ago
tsarina | 10 years and 6 months ago
object(WP_User)#5388 (8) {
  object(stdClass)#5375 (12) {
    string(5) "14317"
    string(7) "tsarina"
    string(34) "$P$Bcq1JZMILDUhIuz8TRa42423GeMJO1."
    string(7) "tsarina"
    string(18) "goddaiva@gmail.com"
    string(22) "/forums/users/tsarina/"
    string(19) "2017-08-10 14:01:29"
    string(7) "tsarina"
  int(14317)
soap scum is just as bad as grease. baking soda with vinegar, followed with a big shot of hot water, will help keep pipes et a clear. Get a drain guy to clear it out and them keep it maintained.
chjuran | 10 years and 6 months ago
object(WP_User)#5387 (8) {
  object(stdClass)#5386 (12) {
    string(6) "184860"
    string(7) "chjuran"
    string(34) "$P$BJdzTqKwgM0oQoXuprDAQXT7RLe6Ap1"
    string(7) "chjuran"
    string(18) "kerik100@gmail.com"
    string(7) "chjuran"
  int(184860)
My goodness. Don’t put drano or grease in the drain. You don’t need a licensed plumber, a handyman with a $10 off-the-shelf drain snake will likely be able to clear the line.
mozeeatupu | 10 years and 6 months ago
object(WP_User)#5382 (8) {
  object(stdClass)#5389 (12) {
    string(6) "176749"
    string(10) "mozeeatupu"
  int(176749)
Never put grease down a drain regardless of adding hot water. Somewhere in the pipe it’ll cool, congeal and block.
Arkady | 10 years and 6 months ago
  object(stdClass)#5390 (12) {
If you mix grease w/ very hot water & dishwashing liquid it helps.
adam_dahill | 10 years and 6 months ago
  object(stdClass)#5391 (12) {
    string(6) "176783"
    string(11) "adam_dahill"
    string(63) "$wp$2y$10$lFy8.3pnrUx7r.zy2UuZY.pzkkcGjgJt5QNgwyohfpJ4XzygVeReW"
    string(20) "adamdahill@gmail.com"
    string(39) "https://www.mortgagemaster.com/adahill/"
    string(19) "2013-06-24 16:57:52"
  int(176783)
I recently had my sewer line professionally snaked for the same reason. Tub and toilet on garden floor wasn’t draining. They recommend you do it once a year. It’s $50 per drain and I had to do it 3 times so ended up being $150 plus tax. Once out to the street and twice up into the house. There was a blockage of grease and hair. Make sure you don’t pour cooking grease down the kitchen sink.
daveinbedstuy | 10 years and 6 months ago
  object(stdClass)#5392 (12) {
Plunger? Draino????
GreenThinker | 10 years and 6 months ago
  object(stdClass)#5393 (12) {
    string(5) "98498"
    string(12) "GreenThinker"
    string(12) "greenthinker"
  int(98498)
Most likely it’s a build up of hair and gunk that isn’t letting the water through. Take a clothes wire hanger cut a 10 inch piece out of it and bend one end into a hook. Remove the drain stop/plug and pull out the blockage.
