AC Plugs
I want to re-do electric on my home. Does the code require that every window must have a plug for an AC unit?
basementbound
in About Brooklyn 10 years and 3 months ago
basementbound | 10 years and 3 months ago
object(WP_User)#5305 (8) {
  object(stdClass)#5294 (12) {
    string(6) "176760"
    string(13) "basementbound"
    string(34) "$P$BhooDZFbH1SfFwlIRtDuMZUT1mN9Vu/"
    string(20) "filmturner@gmail.com"
    string(28) "/forums/users/basementbound/"
  int(176760)
Thank you
MASTERELECTRICIAN | 10 years and 3 months ago
object(WP_User)#5304 (8) {
  object(stdClass)#5303 (12) {
    string(6) "126986"
    string(17) "MASTERELECTRICIAN"
    string(22) "master-electrician-2-2"
    string(18) "wirelights@aol.com"
    string(19) "2017-08-17 21:34:28"
    string(18) "MASTER ELECTRICIAN"
  int(126986)
Yes they must be arc fault circuit breakers. Don’t recall if there is any specific distance requirements, adjacent to the window is ok. Most a/c units come with a 6 foot cord so the outlet would have to be close by. Your electrician should know this too.
object(WP_User)#5294 (8) {
  object(stdClass)#5300 (12) {
    string(6) "176760"
  int(176760)
What is the min or max distance does the plug have to be from the window? Thank you again for your input.
  object(stdClass)#5306 (12) {
    string(6) "176760"
  int(176760)
Thanks for your response. Would they require Arc breakers?
object(WP_User)#5300 (8) {
  object(stdClass)#5304 (12) {
    string(6) "126986"
  int(126986)
The code states that every room must have an outlet on a separate circuit for A/C use unless the space is equipped with central air conditioning. As stated above kitchens and bathrooms are exempt. Your electrician should know this.
GreenThinker | 10 years and 3 months ago
object(WP_User)#5306 (8) {
    string(5) "98498"
    string(12) "GreenThinker"
    string(12) "greenthinker"
  int(98498)
Every room except bathrooms and kitchens should have a AC receptacle by one of the windows. Usually i choose which window would make more sense for a AC or just put a receptacle between two windows.
