ISO Window Replacement Recs (Including Painting & Sill replacement)
Hi – We finally are ready to pull the trigger on the window replacement in our house. I have researched and researched over the years. I have talked to a number of the window replacement companies that are recommended on these forums including LWP and Windows We Are. I think we really want someone who can also handle the painting and woodwork that is going to be associated with the project. Any recommendations for that kind of work? Thanks!
anne_nyc
in Doors & Windows 12 years and 5 months ago
jbrew | 12 years and 5 months ago
object(WP_User)#5043 (8) {
string(6) "176826"
string(5) "jbrew"
string(34) "$P$BPqAWgC65b/AYerB7FgDxQKIU6TS6e."
string(5) "jbrew"
string(25) "Jbrew@heightshistoric.com"
string(46) "http://www.brownstoner.com/forums/users/jbrew/"
string(19) "2017-08-10 14:16:43"
string(5) "jbrew"
int(176826)
Hi Anne, give me a call, I am with Heights Historic Window and Door, we will replace your windows and take care of painting also. 347-881-6962 Jeff
mruby36 | 12 years and 5 months ago
object(WP_User)#5042 (8) {
object(stdClass)#5041 (12) {
string(6) "176799"
string(7) "mruby36"
string(7) "mruby36"
string(15) "matt@nyc-hs.com"
string(6) "Matt R"
int(176799)
Not a window specialist here. More suited to overall woodworking, light construction and have certainly replaced a window or two over the years, replacement windows into existing trimmed openings or remove and replacement jobs. Specializing. In some situations, a specialist vs a generalist is the way to go, in others, not so much. It sounds like you may have a circumstance where the replacement is straightforward enough, and at the end of the day (job), you want to look at and live with quality woodworking / painting craftsmanship. If this is the case, then please reach out with more details; as what I do may be a good match for what you’re looking for. If your situation involves specific historic / landmark customization, than I am not likely a good fit and would certainly let you know that as soon as it became apparent. Welcoming the opportunity to speak further, Matt R www.nyc-hs.com
masterbuilder | 12 years and 5 months ago
object(WP_User)#5038 (8) {
object(stdClass)#5044 (12) {
string(5) "26835"
string(13) "masterbuilder"
int(26835)
We typically only install windows as part of larger jobs. Due to an increase in positive relationships with window vendors this past year, we have taken on some window install projects. If schedule allows, we certainly would not turn the work down, so feel free to contact us. masterbuildernyc@gmail.com www.bgrbuild.com
zydac | 12 years and 5 months ago
object(stdClass)#5045 (12) {
string(4) "3524"
string(5) "zydac"
string(34) "$P$BAackAL3zgiCQ8l45quzGNOskDpZ2S0"
string(5) "zydac"
string(19) "zydac@ix.netcom.com"
string(19) "2017-08-10 13:43:08"
string(5) "zydac"
int(3524)
We are looking for the same thing! Our problem is that it is only one window, so the job is too small for most experienced contractors and too potentially difficult for small contractors. Basically we need a GC who does windows as well.
