Creating a Door
I would like to cut a new doorway through a wall in my co-op to combine units and I was wondering what a ballpark cost on such a job might be. It is not a load bearing wall and I spoke with the super who told me it?s just a matter of cutting through. The building was built in the 1950s and the wall is a mix of plaster and chicken wire. I don?t need to put in a door, just an opening. Anyone have any experience with this and how much it might roughly cost? Thanks
mrlithe
in Doors & Windows 10 years and 3 months ago
Guest User | 10 years ago
string(6) "196477"
Interesting stuff to hear! A doorway leads to a creative interior to the home. But along with it, it is important to have a impact doors which can safeguard your home as well as give the new and interesting look to the home. My neighbor had such plans and he researched around with [impact doors Miami](http://www.impactresistantwindowsndoors.com/impact-doors-miami/), doors fort Lauderdale and made it suitable to establish a new doorway within his house. It was cheap and in the budget.
BobMarvin | 10 years and 1 month ago
object(WP_User)#5112 (8) {
  object(stdClass)#5115 (12) {
fredbdaniel: huh? Could you please translate that into comprehensible English
tatepittman | 10 years and 1 month ago
object(WP_User)#5117 (8) {
  object(stdClass)#5123 (12) {
    string(6) "195319"
    string(11) "tatepittman"
    string(34) "$P$Bg666Y6nMlYEd94li4hB5JeYjIvOWz."
    string(28) "biancajaspertry853@gmail.com"
    string(19) "2024-03-26 05:32:38"
  int(195319)
As the building too old, i would certainly recommend to go for a plaster and to have a new construction of wall before resetting a new doorway.
mrlithe | 10 years and 3 months ago
object(WP_User)#5116 (8) {
  object(stdClass)#5118 (12) {
    string(5) "59935"
    string(7) "mrlithe"
    string(34) "$P$BSGrlu42cSjmFWfuHFezFSyDqpuO4Q0"
    string(7) "mrlithe"
    string(23) "jasonstefanik@gmail.com"
    string(48) "http://www.brownstoner.com/forums/users/mrlithe/"
    string(19) "2017-08-10 14:28:56"
    string(7) "mrlithe"
  int(59935)
The super is new to the building so not sure if he knows anyone. He would most likely recommend one contractor who has done a ton of work in the building and I’ve used him before for other jobs, but I found him over priced and his work barely adequate. So I was hoping people on the forums might have some good referrals.
daveinbedstuy | 10 years and 3 months ago
  object(stdClass)#5124 (12) {
Can the super not recommend someone? It’s a relatively simple and straighforward job ewith perhaps the largest issue being to minimize the dust on demolition.
object(WP_User)#5118 (8) {
  object(stdClass)#5117 (12) {
    string(5) "59935"
    string(7) "mrlithe"
    string(7) "mrlithe"
    string(7) "mrlithe"
  int(59935)
Thanks! Do you know anyone who does that kind of job regularly or anyone you would recommend?
Augustiner | 10 years and 3 months ago
  object(stdClass)#5125 (12) {
Depends a bit on the circumstances The floor transition has to be refinished. Hard to say – but anywhere between $ 2500-5000\. The cheaper solution is to use a door frame/ trim, because you won’t have to do plasterwork an repaint both sides
