Turning small bathroom into a wet room...need advice
Looking for advice about whether and how to do this. Interested in hearing from people who have done this.
ctk
in Plumbers and Plumbing 14 years and 2 months ago
daveinbedstuy | 14 years and 2 months ago
object(WP_User)#5041 (8) {
object(stdClass)#5016 (12) {
I did this about 18 years ago the old fashioned way: Durock and tile with a floor drain. It has never leaked or been a problem but I would recomment the newer technologies as described above. I bet you could find a video of them on the This Old House website.
masterbuilder | 14 years and 2 months ago
object(WP_User)#5040 (8) {
object(stdClass)#5039 (12) {
string(5) "26835"
string(13) "masterbuilder"
int(26835)
We use the same method as listed above. A Brownstoner poster reached out to me last year to correct a faulty install of the same product in a shower (apparently the previous homeowner had performed the work). I’ve used the product subsequently and also use the product for exterior waterproofing applications. Correctly installed, it is the way to go. If you want to spray water throughout the room, you will want to hire someone diligent about waterproofing.
greenmountain | 14 years and 2 months ago
object(WP_User)#5036 (8) {
object(stdClass)#5042 (12) {
string(5) "12939"
string(13) "greenmountain"
int(12939)
I am in the Brownstoner directory under shower stalls. I use a waterproof membrane and set the tile directly to it. It is not a shower pan. Not lead, not vinyl. I have made exterior windows, in showers leak- proof. I use it in tub surrounds, shower stalls, laundries, and as you describe “wet rooms.” The membrane has a special compatible drain, which is also 100 % direct drainage, not like a “two stage” drain used with a pan system. Of course, like a shower stall, if you block the drain, water will eventually overflow at the lowest points usually the toilet flange and threshold. None of my clients have blocked their drains or had floods. I seal or elevate low points according to conditions of each job. You asked. I understand you would like to hear from a home owner. Not so many in our area use the method I do. It is not propriatary, but you do have to contact me directly. This is self promotion, but not the same as the window company which posted above me. They appear to be a manufacturer or major distributor of a product with no personal contact with home owners on this list. I am a local craftsperson who contributes to the discussion here, and frequently visits the homes of participants, where I offer complimentary professional advice. I am not able to offer the names of my clients here, but of course I offer references to those seriously considering my service. Green Mountain Construction & Design
