Plumbing inspection
Once a plumbing inspection either self inspection or by DOB is complete do we need to do another one?
allyslope
in Plumbers and Plumbing 12 years and 3 months ago
steam_man | 12 years and 3 months ago
object(WP_User)#4996 (8) {
  object(stdClass)#5021 (12) {
    string(6) "176846"
    string(9) "steam_man"
  int(176846)
It should say Final. Aside from BIS you should know yourself. The Rough inspection is everything behind the walls. The Final is well…the final.
allyslope | 12 years and 3 months ago
object(WP_User)#4997 (8) {
  object(stdClass)#4998 (12) {
    string(6) "180670"
    string(9) "allyslope"
  int(180670)
How do you tell on the DOB site if it is rough or final? I already have a new GAS meter
object(WP_User)#5001 (8) {
  object(stdClass)#4995 (12) {
    string(6) "176846"
  int(176846)
Depends on which inspection, rough or final? If it’s final then no. If its rough then yes. Also, If it is for gas and involves a new meter then you will have inspections by DOB and then Con Ed or National Grid. Your meter won’t be released until Gas Final is checked off on BIS.
