Insulating thick cold water pipes
We have 1 3/4″ cold water supply pipes coming into our building. I would like to use foam insulation to cut down the condensation and just because it is cheap to insulate. Foam only seems to come up to 1 1/2″. Anyone know if I should just use 1″ and 3/4″ and tape them together or if someone makes wider insulation? Maybe a wrap around solution?
funstraw
in Plumbers and Plumbing 13 years and 1 month ago
funstraw | 13 years and 1 month ago
object(WP_User)#5091 (8) {
object(stdClass)#5120 (12) {
string(4) "2336"
string(8) "funstraw"
string(63) "$wp$2y$10$IOnd2GZlgG2iEPK1K4ZByeyZ0Irma/6FUpK0IrmIwGz2hcLC1k4Wy"
string(18) "funstraw@gmail.com"
string(23) "/forums/users/funstraw/"
string(19) "2017-08-10 14:12:40"
int(2336)
So they measure the inside of the pipe for exterior insulation, interesting. Thanks, I’ll look into that.
steam_man | 13 years and 1 month ago
object(WP_User)#5092 (8) {
object(stdClass)#5093 (12) {
string(6) "176846"
string(9) "steam_man"
int(176846)
You are most likely measuring the outside diameter of the pipe. In which case your pipes are either 1-1/2″ or 1-1/4″. Order your insulation based on one of those two sizes (whichever is yours). OD for 1-1/2″ pipe is around 1.9 inches (1-7/8).
object(WP_User)#5120 (8) {
object(stdClass)#5097 (12) {
string(4) "2336"
int(2336)
That’s great thanks. If anyone had anything local I would check that out as well.
stevecym | 13 years and 1 month ago
object(stdClass)#5090 (12) {
check McMaster Carr Supply on line. Steve
