flooded backyard.....sewer service or plumber?
Last Sunday, during those very heavy rains, my back yard turned into a lake. Water flowed under the door of the ground floor apartment and the tenant justifiably went a little crazy.
There is a drain in the ground toward the back of the yard connected to a pipe. But my guess is that it hasn’t worked in years and even if it does I don’t think it is in the best location. What I need is someone to analyze the situation and do whatever is necessary so a flood does not recur.
sewer service? or plumber? any recommendation?
starfish11040
in Plumbers and Plumbing 14 years and 8 months ago
Arkady | 14 years and 8 months ago
object(WP_User)#5138 (8) {
  object(stdClass)#5085 (12) {
French drain isn’t that expensive – that’s what I’d do after snaking the drain pipe.
NewOwner | 14 years and 8 months ago
object(WP_User)#5137 (8) {
  object(stdClass)#5136 (12) {
    string(5) "36874"
    string(8) "NewOwner"
    string(63) "$wp$2y$10$DNiCPOIVV7BUnn9MhQheBOPsZ/592M4KofHPVw6l5SPGGcXrzDtOe"
    string(13) "new-owner-2-2"
    string(18) "funkez@hotmail.com"
    string(28) "/forums/users/pheights_lady/"
    string(19) "2017-08-17 21:40:38"
    string(60) "1759521590:$generic$Xl2TchCT5lHfSSjE3lsON70K6NSR1XjhBzV7ir5X"
    string(9) "New Owner"
  int(36874)
I’ve had luck with those $49.99 sewer people for outside clogs.  I think that this is the place I used, but there seems to be many similar businesses:  www.a4999**sewer**.com/
It’s literally $49.99 for the job, plus a tip to the guy.
brucef | 14 years and 8 months ago
object(WP_User)#5133 (8) {
  object(stdClass)#5139 (12) {
    string(4) "4724"
    string(6) "brucef"
    string(6) "brucef"
    string(6) "brucef"
  int(4724)
Please check my extensive answer about a week ago to the same question.
Silvermax | 14 years and 8 months ago
  object(stdClass)#5140 (12) {
    string(5) "29536"
    string(9) "Silvermax"
    string(27) "MarthaCameron@earthlink.net"
    string(24) "/forums/users/silvermax/"
    string(19) "2009-04-21 17:51:30"
  int(29536)
The drain at the back probably needs cleaning out — if you don’t do it a couple of times in the season, it gets totally clogged with mud. Location may be fine if your yard is sloped slightly away from the house — I think it’s 1/4-inch per foot slope. If it’s a persistent problem, you could have a trench drain installed along the back of your house — a drain that is connected directly to your sewer line. Not cheap, but water won’t come into your house again. That would require a contractor, I would think — a plumber. But start with the existing pipe — lift the drain top and see if there’s a lot of dirt there and muck it out. Last Sunday set a record for rainfall in a single day in NYC. Sadly, the record will probably fall within a few years…
