do I need permit to replace drain on backyard?
Hi, recently the drain in my backyard got cloged an water spills into basement through the rear hatch. I want plumber to fix the drain. He probably will change piece of piple and replace the concrete pavement around the darin. So the question is: do I need permit for this. The pavement is on the backyard under the deck. From one side it is visible for every snitch-neighbour, it is sort of plumbing and it is under the deck. From the ofther point does the govement need to stick its corrupted nose into the business or replacing a drain?
bobjohn
in Plumbers and Plumbing 13 years and 10 months ago
ellenlourie | 13 years and 10 months ago
object(WP_User)#5134 (8) {
object(stdClass)#5114 (12) {
this repair can be done on op128, monthly plumbing report, sent by a plumber to DOB monthly
jockdeboeraia | 13 years and 10 months ago
object(WP_User)#5133 (8) {
object(stdClass)#5132 (12) {
string(5) "40876"
string(13) "jockdeboeraia"
int(40876)
Yep, have him pull an lla-1.
