2 Families brownstone. Conventional Water Heater or Tankless Water Heater?
http://cdn.brownstoner.com/4f72e29a7938c-.png
I have seen and used bathrooms with tankless water heaters in my trips to Europe but right now I have to decide for a two families in Brooklyn. Anybody in the forum has seen/experienced how well a tankless water heater for a traditional two families Brooklyn? Any opinion you can share? Can you compare it with a conventional 50 or 75 gallons high efficiency water heater?
brklynreno
in Plumbers and Plumbing 13 years and 11 months ago
Master Plvmber | 13 years and 11 months ago
object(WP_User)#5049 (8) {
object(stdClass)#5037 (12) {
slopegirl | 13 years and 11 months ago
object(WP_User)#5048 (8) {
object(stdClass)#5047 (12) {
string(5) "34682"
string(9) "slopegirl"
int(34682)
check the archive. i remember reading master plumber posting an article (or link to one) about why not tankless… I think if it’s more than occasional use, it’s not better, but I may not be summarizing that right. anyway, there have been previous discussions on this. might be worth a spin through the archive for more info.
catboot | 13 years and 11 months ago
object(WP_User)#5044 (8) {
object(stdClass)#5050 (12) {
string(5) "56593"
string(7) "catboot"
string(7) "catboot"
string(7) "catboot"
int(56593)
We just had to make the same decision about a month ago. We really wanted to go with the tankless heater, but in the end the conventional kind was the one we got. If we were a single family house, I probably would have chosen the tankless kind – they are really most efficient when you don’t constantly run hot water. We ended up with a 50 gallon unit – so far so good.
brewguy | 13 years and 11 months ago
object(stdClass)#5051 (12) {
string(5) "30906"
string(7) "brewguy"
string(7) "brewguy"
string(14) "mike@benit.com"
string(48) "http://www.brownstoner.com/forums/users/brewguy/"
string(19) "2017-08-10 13:47:15"
string(7) "brewguy"
int(30906)
Check with a plumber before you buy. I had hoped to install one after my wh died a couple of years ago and for some reason (which I don’t remember why) there was a code issue I couldn’t work around.
nintzk | 13 years and 11 months ago
object(stdClass)#5052 (12) {
string(6) "178934"
string(6) "nintzk"
string(34) "$P$BUfz7HeZ8wh2u8cbfqG4t5t0Q7xX8J1"
string(6) "nintzk"
string(15) "melnitzk@yu.edu"
string(21) "/forums/users/nintzk/"
string(19) "2017-08-10 14:37:09"
string(20) "shWhXZlPLFKpPADXeptX"
string(6) "nintzk"
int(178934)
where do these tankless water heaters go? The basement? Is it one for each bathroom?
Bklnite | 13 years and 11 months ago
object(stdClass)#5053 (12) {
string(4) "7850"
string(7) "Bklnite"
string(7) "bklnite"
string(7) "Bklnite"
int(7850)
75 gallons seems like overkill for a 2 family – you’d probably do fine with a 50.
jockdeboeraia | 13 years and 11 months ago
object(stdClass)#5054 (12) {
string(5) "40876"
string(13) "jockdeboeraia"
int(40876)
You will need two. Check the manuf. specs of the unit you want to buy, they will have guidelines for how many fixtures and what size to buy.
