What to do about a rat hole?
I recently noticed that there is a decent sized hole (about 3-4 inches in diameter) in my front garden right underneath the fence that separates my yard and the sidewalk. I assume it is a rat hole and want to get rid of them.  I don’t want to use any poisons because I wouldn’t want a dog walking by on the sidewalk to get hurt.   Any ideas how to get rid of the hole’s inhabitants before I call pest control?  And if pest control _is_ the best option, any recommendations of companies I should call? Thanks!
borderline
in Pest Control 14 years and 1 month ago
pmhcuuxmobsohz | 12 years and 4 months ago
object(WP_User)#5054 (8) {
  object(stdClass)#4998 (12) {
    string(6) "209632"
    string(14) "pmhcuuxmobsohz"
  int(209632)
The number-one concept in packing for a vacation would be to package softly simply because we often neglect how frequently we’re going must lift as well as bring all of our baggage in the course of each of our moves.??????? ?????? [url=http://www.libertynewstv.org/]www.libertynewstv.org[/url] ??? ??????,????????????? [url=http://www.degreesofemotion.com/]??? ??[/url] ??? ?? ??,?? ??? [url=http://www.bestzeolite.com/]?? ???[/url] ?? ???, Take into account exactly how, you’ll shifting your current baggage into your back of your respective auto as well as out and about once more, with the airport terminal, away from the luggage slide carousel, by one more international airport, around often the start of the local rental vehicle as well as available once again until finally ultimately you will get to typically the hotel everywhere ideally they are going to possess a porter. ??????? ?? [?????? ???](http://www.libertynewstv.org/) ??????? ??????,????????????? ??? ??? ??,??? ?????? [??? ???](http://www.degreesofemotion.com/) ??? ??? ??,?? ??? ??? [?? ???](http://www.bestzeolite.com/) ?? ??? ??,Together with requiring you to tote your own personal hand bags close to, your current air travel will have stringent regulations about the measurement, ??????? ?? www.libertynewstv.org,??? ??? ?? www.degreesofemotion.com,?? ??????? www.bestzeolite.com,weight plus the volume of carriers you may journey with-for both equally carry on in addition to checked gear.
shahnandersen
object(WP_User)#141285 (8) {
  object(stdClass)#5063 (12) {
    string(1) "6"
    string(13) "shahnandersen"
  int(6)
What’s the problem with throwing packets of rat poison down the hole?
slopegirl | 14 years and 1 month ago
object(WP_User)#141287 (8) {
  object(stdClass)#141288 (12) {
    string(5) "34682"
    string(9) "slopegirl"
  int(34682)
cue the caddy shack clips
nf85 | 14 years and 1 month ago
object(WP_User)#141286 (8) {
  object(stdClass)#141289 (12) {
    string(5) "97592"
    string(4) "nf85"
    string(4) "nf85"
    string(16) "fabens@gmail.com"
    string(4) "nf85"
  int(97592)
Seward, my brothers and I did this all the time as kids to ground squirrels–it really does work. But yeah, you need to be ready with the bag pretty quick as they pop right out.
bowl-of-dicks | 14 years and 1 month ago
  object(stdClass)#141290 (12) {
    string(5) "12647"
    string(13) "bowl-of-dicks"
    string(15) "cf80q@yahoo.com"
    string(13) "bowl of dicks"
  int(12647)
Smoke bombs…. typically used for them pesky gophers, out in the country. ,
SewardWasRight | 14 years and 1 month ago
  object(stdClass)#141291 (12) {
    string(5) "52609"
    string(14) "SewardWasRight"
    string(7) "usgrant"
    string(7) "USGrant"
  int(52609)
Oooo! I’ve been dying to recomend this to someone – put your hose as far down the hole as possible and then turn the spigot on full blast! If there is anything down there it’ll escape out its back hole – and if it does not and tries to get up through the hole with the hose, well…are you ready? then the DOB can site him for not having a secondary means of egress! Solved! OK, seriously, though, try the hose and see what happens. It might not be permanent, but you just might see where the hole leads to.
