Help - how do I remove nest of birds in opening in roof area?
Hi there. I am a newbie brownstone owner (just closed in March). My neighbor pointed out that I have birds entering/exiting via a hole on the side of my roof area. Lo and behold, I saw 2 birds. I can’t tell what the material is up there. I called pest control companies and they indicated they don’t have ladders high enough to get to the roof. One suggested that I use a general contractor. Does anyone have any suggestions/recommendations? HELP!
lyndapak
in Pest Control 11 years and 9 months ago
mikegray | 11 years and 7 months ago
object(WP_User)#5032 (8) {
object(stdClass)#4979 (12) {
string(6) "182453"
string(8) "mikegray"
string(34) "$P$BE8lFzzeYRc.E7f8v0DSlfLIxbq2Ub1"
string(28) "eastcoastroofingny@gmail.com"
string(30) "http://eastcoastroofingny.com/"
string(19) "2017-08-10 13:48:23"
int(182453)
[East Coast Roofing](http://eastcoastroofingny.com/) has worked for hundreds of satisfied homeowners and many contractors. If you need a new roof or just have a problem with your existing one, East Coast Roofing has the experience and staff to get the job done right the first time.
kachuri999 | 11 years and 9 months ago
object(WP_User)#5031 (8) {
object(stdClass)#5030 (12) {
string(6) "177796"
string(10) "kachuri999"
string(34) "$P$B/0Fj2r80af0pTJ4PWxP4OvPETjrhg1"
string(21) "mmiranda999@gmail.com"
string(25) "/forums/users/kachuri999/"
string(19) "2017-08-10 14:27:02"
int(177796)
We had the same issue last summer. It started in spring last year, every morning at about 4 or 5 am I’d hear birds and squirrels scurrying about. It was crazy loud. We then realized that we had 2 large holes in our cornice (since it’s painted black it was hard to see at first). We hired a contractor to close the holes. I think they used it as warm refuge in the spring because by summer (when we closed the holes) the area was empty. Since then I haven’t heard/seen anything. The contractor accessed the holes by crawling through the soffit and getting on the roof. I should also mention that in the beginning when I wasn’t sure what animal was up there I had our exterminator check it out and they placed baits in case there were rats (that didn’t make the animals go away). I didn’t have much success in getting Animal Control to come and trap whatever was up there.
ventilated | 11 years and 9 months ago
object(WP_User)#5033 (8) {
object(stdClass)#5034 (12) {
string(6) "176829"
string(10) "ventilated"
int(176829)
There are some companies that will try to reach from your roof (depending on type of roof, etc.). But a word of caution, you MUST use someone familiar with birds and bird mites, otherwise you risk a bird mite infestation a million times worse and harder to eliminate than bedbugs. http://www.birdmites.org/
rh | 11 years and 9 months ago
object(WP_User)#5027 (8) {
object(stdClass)#5035 (12) {
string(4) "3878"
string(2) "rh"
string(2) "rh"
string(2) "rh"
int(3878)
I would start with a bird rescue group. This way you don’t harm the birds and it’s a win/win situation. http://citybirder.blogspot.com/p/wildlife-rescuers.html
