OASIS Building Size numbers wrong - Need some advice
Hi, I looked up our building on OASIS and our building size number is completely wrong. It has the following numbers: Lot Area:1,917 sq ft (19′ x 100.92′) # of Buildings:1Year built:1910 # of floors:4Building Area:**12,168 sq ft** Our neighbor who lives in an identical brownstone (same size, depth, garden size etc.) has the following: Lot Area:1,917 sq ft (19′ x 100.92′) # of Buildings:1Year built:1910 (Year built is an estimate) # of floors:4**Building Area: 3,952 sq ft** What I am worried about is the tax abatement on the building runs out next year and will this huge mistake in the building area size effect what we will be taxed? Also, is there any way we can find out roughly what we might be taxed?
Any help much appreciated! Thanks.
kissiffer4
in Lawyers and legal service 13 years and 11 months ago
dazednconfused2 | 13 years and 11 months ago
object(WP_User)#5090 (8) {
object(stdClass)#5135 (12) {
string(6) "209624"
string(15) "dazednconfused2"
int(209624)
The links you posted aren’t coming through with the actual address so I can’t see the records. The DOF link would be listed as :NYC Dept. of Finance Assessment Roll That third link you posted goes to the DOF, so maybe that’s it. If that’s where it says 4,065, you’re probably fine. You should probably verify this with a real estate attorney.
kissiffer4 | 13 years and 11 months ago
object(WP_User)#5091 (8) {
object(stdClass)#5092 (12) {
string(5) "36622"
string(10) "kissiffer4"
string(20) "cfrankland@gmail.com"
string(18) "/forums/users/csf/"
string(19) "2009-08-24 01:24:21"
int(36622)
object(WP_User)#5095 (8) {
object(stdClass)#5089 (12) {
string(5) "36622"
int(36622)
OK, Jim, I looked up our place on this site: https://a836-propertyportal.nyc.gov/ It has the building area at 4,065 sq. ft. Does that mean we are OK then as far as them having the correct info for property tax?
Thanks 🙂
object(WP_User)#5092 (8) {
object(stdClass)#5090 (12) {
string(5) "36622"
int(36622)
Hi Jim,
I can’t seem to find a link to the DOF. Do you happen to know what it is? I found one to the DOB, not sure if this is the right place to be looking: http://a810-bisweb.nyc.gov/ Thanks.
object(WP_User)#5089 (8) {
object(stdClass)#5091 (12) {
string(6) "209624"
int(209624)
Oasis pulls information from a few databases, not the other way around, so there’s nothing to worry about in terms of what it says there. However, it may mean that the database it pulls from is supplying the same erroneous information to other agencies. You can check the DOF records from the Oasis link and see what is shown at the DOF records, and contact them if there are errors. I had to do that once and it was actually quite easy.
