Seeking kitchen designer (not architect)
Hi, I am looking for recommendations for a kitchen designer to remodel a Brooklyn kitchen. Looking to go somewhat high end, but it’s not a terribly complicated job (just replacing cabinets that are there now, keeping appliances, not a major rethink of the space) so I don’t think an architect is necessary. Basically looking for someone with creative vision to work with us to lay out choices in materials and then ultimately create (beautiful) detailed plans that I’d give to my contractor to execute on. If anyone has someone to recommend, please send suggestions!
carolynweiss
in Bath & Kitchen 13 years and 1 month ago
janeinteriorsnyc | 12 years and 4 months ago
object(WP_User)#5167 (8) {
object(stdClass)#5178 (12) {
string(5) "17657"
string(16) "janeinteriorsnyc"
string(34) "$P$BGSbxeYZ3BZXNg70uVdHg7ER8Ve/R11"
string(22) "jane-interiors-nyc-2-2"
string(25) "jane@janeinteriorsnyc.com"
string(31) "http://www.janeinteriorsnyc.com"
string(19) "2017-08-17 21:35:36"
string(18) "jane interiors nyc"
int(17657)
I do gut renovations and simple kitchen remodeling. I think you save money in the long run having a designer who can sensitively use your budget to create the most impact for your dollar. My clients always say that I thought of things they hadn’t thought of. www.janeinteriorsnyc.com
pmhcuuxmobsohz | 12 years and 5 months ago
object(WP_User)#5168 (8) {
object(stdClass)#5169 (12) {
string(6) "209632"
string(14) "pmhcuuxmobsohz"
int(209632)
The particular number-one rule with taking for any getaway is to packs carefully because we sometimes ignore the frequency of which we are going to have to elevate or maybe hold the bags through each of our trips.??? ?????? [MCM ??](http://www.libertynewstv.org/) ?????? ??,????????????? ?????? [??? ??? ??](http://www.degreesofemotion.com/) ??? ??????,?? ??????? [?? ???](http://www.bestzeolite.com/) ?? ???, Think about precisely how, you’ll be dragging your personal baggage into your start of your respective auto and also out and about once more, throughout the air port, off the bags slide carousel, by way of a different international airport, around the shoe of your respective rental auto along with away once again right up until lastly you’re able to the particular hotel exactly where hopefully they will have got a avoir. ??????? ?? [??????? ??????](http://www.libertynewstv.org/) ?????? ???,????????????? ?? ????? ??? ??,??? ??? [??? ??? ??](http://www.degreesofemotion.com/) ??? ??????,ugg ??? [?? ??? ???](http://www.bestzeolite.com/) ?? ??? ??,Along with requiring you to tote your bags around, your own commercial airline will have strict guidelines about the dimensions, ??????? ?? http://www.libertynewstv.org/,??? ??? http://www.degreesofemotion.com/,?? ??????? www.bestzeolite.com,excess weight plus the amount of totes you could traveling with-for equally carry on bag and also checked luggage.
grayhope | 13 years and 1 month ago
object(WP_User)#5172 (8) {
object(stdClass)#5166 (12) {
string(6) "177550"
string(8) "grayhope"
string(34) "$P$BomYjC2fEBQ7yNjLUE4ugNgB/lh69g."
string(20) "gray.hope9@gmail.com"
string(49) "http://www.brownstoner.com/forums/users/grayhope/"
string(19) "2017-08-10 14:20:51"
int(177550)
I have used Kitchen Cabinet Kings and I was quite delighted with the cabinets and the design of my kitchen. If you haven’t found one yet you can try them. http://www.kitchencabinetkings.com +++ Authentic wood, good quality, fast – none so far – none so far
curated | 13 years and 1 month ago
object(stdClass)#5165 (12) {
string(6) "176931"
string(7) "curated"
string(7) "curated"
string(15) "c@curatedny.com"
string(7) "curated"
int(176931)
Yes we do both the design and install. We mostly do custom cabinets so do not have a showroom as each project is very specific. We deal with many custom cabinet makers and semi-custom cabinet manufacturers. Depending on your needs and budget we can reccommend the route to head in. Picking the actual cabinetry is usually the easier part. Making sure the layout, design and utilization of the space is correct is what is more important. Feel free to contact us. http://brownstoner.staging.wpengine.com/curated
object(stdClass)#5164 (12) {
string(6) "176931"
string(7) "curated"
string(7) "curated"
string(7) "curated"
int(176931)
As mentioned some better cabinet places will provide you drawings once you place an order. It is highly advisable though to have your contractor check measurements before placing the order. Many of the so called kitchen designers in the cabinet showrooms have very little actual construction knowledge which can lead to cabinets being ordered that don’t properly match and utilize your space. Since we do design/build we provide these drawings to our clients for approval prior to ordering cabinets and so that our carpenters can use during the install. http://brownstoner.staging.wpengine.com/curated
nyc_sport | 13 years and 1 month ago
object(stdClass)#5163 (12) {
string(5) "39535"
string(9) "nyc_sport"
string(16) "btfraw@yahoo.com"
int(39535)
Are you going with stock/semi-custom cabinets? If so, not sure of the need for a separate kitchen designer, particularly if you are primarily just doing cabinets. You can probably accomplish what you seek if you go to an established dealer of the high end “semi-custom” cabinet companies (i.e., Woodmode, Plain and Fancy), all of which will include design services. There is a good Woodmode dealer in the D&D building in Manhattan. If you are going the route of full custom, most custom cabinet shops also design kitchens — A few colleagues of mine have used Ideal Kitchens in NJ for NYC kitchens for design and supply of full custom cabinets.
