opinions needed on kitchen range configuration
I would appreciate opinions on my kitchen dilemma. When we bought our house it came with a 36″ gas professional range that is 16 years old. It is not vented to the outside so we don’t use the grill on the range unless we want a smokefest. What would you do? Since there is no simple fix, I am considering many options: 1) replace the range with a 30″ width range and 30″ non-vented hood and replace the surrounding cabinets and counter so they fit the new range. 2) keep the current range and install a hood to the outside so we can properly use it. If we replace the range at some point, it would need to fit the hood (36″) which means $$. 3) replace the current range with another 36″ range that does not have a grill and can be used without the venting to the outside. Is it worth going with 36″ ranges that are not high end? 4) replace the current range with a gas cooktop, expand the kitchen space and install an electric wall oven. Worth it? Thanks.
brooklynhome
in Bath & Kitchen 14 years and 2 months ago
josh | 14 years and 2 months ago
object(WP_User)#5041 (8) {
object(stdClass)#5016 (12) {
string(4) "9275"
string(4) "josh"
string(63) "$wp$2y$10$5t1OTeXlz.LyaXUgFchhKOi3gMVA6Hua2R0imsDlFuIXHS7RWr.2i"
string(4) "josh"
string(18) "josh@bodeganyc.com"
string(45) "http://www.brownstoner.com/forums/users/josh/"
string(19) "2017-08-10 14:19:47"
string(4) "josh"
int(9275)
A non-vented hood does almost nothing, in my experience.
bobjohn | 14 years and 2 months ago
object(WP_User)#5040 (8) {
object(stdClass)#5039 (12) {
string(5) "15883"
string(7) "bobjohn"
string(7) "bobjohn"
string(7) "bobjohn"
int(15883)
36″ ranges is common place you should add 36″ vented hood. Replacing range with 30″ one and fitting all the cabinets is definitly a bad idea.
jockdeboeraia | 14 years and 2 months ago
object(WP_User)#5036 (8) {
object(stdClass)#5042 (12) {
string(5) "40876"
string(13) "jockdeboeraia"
int(40876)
Either put in the hood, suggested if you actually cook or just get a new range to fit. You do not need to go high end to get a good range, in fact you may be happier.
