>>> Whole House Battery
About once every year— about this time— I post to see if anyone has had any luck navigating through all the complex State and City regulations on installing a whole house battery to “time shift” electric expenses through Time Of Use Billing.
Theoretically, TOU billing and a 14kW battery could save thousands of dollars a year for the typical brownstone owner.
I see Chinese Lithium-Ion batteries are now under $500kW, and the costs of the inverter is basically negligible…. In my case creating a sub $8,000 solution to power the whole house for literally pennies a month.
Anyone have any luck over at the DOB, Fire Dpt and Insurance carrier for either installation or simply news?
Thnx.
jrs84o
jrs84o | 3 years and 10 months ago
object(WP_User)#4993 (8) {
  object(stdClass)#5049 (12) {
    string(6) "189678"
    string(6) "jrs84o"
    string(6) "jrs84o"
    string(16) "jrs84o@gmail.com"
  int(189678)
Also- I don’t think the solar companies are overwhelmingly onboard with whole house battery thing.
Once there is a CLEAR path for adoption it will be easier (and much less expensive) to simply install two boxes in the basement (inverter and battery) vs. $20-30K (after rebates) worth of equipment on the roof.
PLUS
The solar companies will lose their SWEET refund/subsidy deal they have with the state authorities which puts thousands of dollars in their pocket for each installation.
object(WP_User)#4994 (8) {
  object(stdClass)#4995 (12) {
    string(6) "189678"
    string(6) "jrs84o"
    string(6) "jrs84o"
  int(189678)
Ive been following this CLOSELY for 4 years now, nothing seems to get better at the city level.
Two years ago, NYSERDA published a solar/battery model plan…. But I’ve seen no actual implementation or REAL pathway for consumer adoption.
https://www.nyserda.ny.gov/All-Programs/clean-energy-siting/battery-energy-storage-guidebook
Cole | 3 years and 10 months ago
object(WP_User)#5049 (8) {
  object(stdClass)#4998 (12) {
    string(4) "6516"
    string(4) "Cole"
    string(4) "Cole"
    string(27) "cstudebaker@bondnewyork.com"
    string(19) "2008-01-14 20:48:01"
    string(4) "Cole"
  int(6516)
I’ve been told the same (batteries not allowed). However, BSW tells me that it will be easy to retrofit existing solar arrays once they are permitted.
irfan | 3 years and 10 months ago
object(WP_User)#4995 (8) {
    string(6) "189280"
    string(5) "irfan"
    string(34) "$P$BJs4ee.fUAi5QmHT9T0O4EeUJNgiI9."
    string(5) "irfan"
    string(21) "irfan@fieldpromax.com"
    string(19) "2021-12-17 09:43:22"
    string(25) "Field Promax Field Promax"
  int(189280)
As of 3 months ago they are not permitted in nyc per fire code. The fire department doesn’t have the right chemicals to put out a battery fire (or they’re not quickly available) and doesn’t seem like there is any desire to change that. This is from Brooklyn solar works when I spoke with them about solar. Happy to be told things have changed though!
    string(6) "189280"
    string(5) "irfan"
    string(5) "irfan"
  int(189280)
slimc | 3 years and 10 months ago
  object(stdClass)#4991 (12) {
    string(6) "177080"
    string(5) "slimc"
    string(5) "slimc"
    string(5) "slimc"
  int(177080)
You may want to direct this question to solar installers – I think they are current on what is permissible as many of their customers are eager to install a battery to compliment their PV arrays.
