When is engineer required?
When does the DOB require an engineer’s input? I have received conflicting advice. On various DOB website pages I see references to professional engineer OR registered architect. So if one has an architect and feels confident about structural issues, can one forego an engineer? Is there any trustworthy source of information I can go to? Thanks in advance.
Guest User | 4 years and 2 months ago
cate | 4 years and 2 months ago
object(WP_User)#5039 (8) {
object(stdClass)#5022 (12) {
The DOB will accept Alt-1 and Alt-2 filings only from engineers and architects. So you’re required to have one or the other if you’re filing either of those forms. Separately, if you are working on a project with an architect, you may or may not also need an engineer, depending on the project. Often your architect will incorporate an engineer into the project if needed. For example, you may wish to be sure everything is structurally sound before doing renovations or you may need to consult an engineer about proper loads if removing beams or blowing out the back of the house, etc.
