Wall separating gas meters and boilers
If I were to install combi boilers adjacent to my gas and electrical meters… does there need to be concrete block wall between the gas meters and the boilers?
hasibur.rahman07
in General Discussion 4 years and 5 months ago
hasibur.rahman07 | 4 years and 5 months ago
object(WP_User)#4999 (8) {
  object(stdClass)#5024 (12) {
    string(6) "193777"
    string(16) "hasibur.rahman07"
    string(16) "hasibur-rahman07"
  int(193777)
Thanks. Sorry I should have mentioned I was aware of the rule. Was curious if rule for combi boilers was different but that would not make sense actually.
Guest User | 4 years and 5 months ago
string(6) "195579"
the code is clear that you can’t install a new gas meter in the same space as a boiler so logically you shouldn’t be able to install a boiler in the same room as an existing gas meter.
string(6) "195579"
