under stoop iron gate repair/replacement
We have a fairly standard under stoop security gate that has been problematic. It’s shifted such that it doesn’t close without slamming. I’m not clear whether it’s become distorted or whether the stoop that it connects to has shifted. We did a minor repair to it a year ago which fixed things but it’s gotten bad again.
I had one iron worker come look at it and he suggested a new door or an expensive repair. He didn’t think that the repair would last. I’m not opposed to replacing the gate which isn’t particularly nice and isn’t in great shape but I’m worried that the stoop might really be the problem. I’m also worried that removing the existing gate will take a lot of brownstone with it.
Does anyone hae any experience or advice with similar issues and have an iron worker and/or mason to recommend?
Thank you
arewedoneyet
arewedoneyet | 2 years and 11 months ago
object(WP_User)#4991 (8) {
  object(stdClass)#5037 (12) {
    string(6) "177175"
    string(12) "arewedoneyet"
    string(60) "1764158155:$generic$PmHW-7ILQ-A7BrfgVf69Sw4F6thntAV505zKCxgF"
  int(177175)
I can’t find any large cracks or any real sign that the stoop is moving. I suspect it’s maybe swelled a little at the bottom where water may seep in and freeze occasionally. Or it’s just the gate rusting. I’m going to go ahead and get a new door if I can decide who to hire, how much to spend, and what lock setup to use.
Do any of you have recommendations on folks to repair the brownstone after the gate is in?
cate | 3 years ago
object(WP_User)#4992 (8) {
It’s hard to opine from here, but if the stoop is moving, I would imagine you’d see cracks. Our iron gate used to stick at certain times of year, perhaps because of the weather. We got someone to shave off a bit from where it was sticking, around the hasp, and it’s been fine ever since. Maybe check the gate frame, the parts that move, the hinges, make sure they’re not pulling away,
arewedoneyet | 3 years ago
object(WP_User)#4997 (8) {
    string(6) "177175"
  int(177175)
There are some cracks but not so many and considering that the house was last re-surfaced in the 80s it looks pretty good. I can’t see that the stoop is separating from the house either.
JohnHancock | 3 years ago
object(WP_User)#5037 (8) {
  object(stdClass)#4989 (12) {
    string(5) "22067"
    string(11) "JohnHancock"
  int(22067)
Or worse, is it separating from the rest of the house?
cate | 3 years ago
object(WP_User)#4990 (8) {
Do you see cracks in the stoop?
