Trespa Exterior Home Siding
We’re thinking about using Trespa Pura NFC siding for the back facade of our home. The sample looks great, but I worry that the faux wood look may look cheap on the house. Does anyone had positive experiences with Trespa or other wood siding alternatives?
mschmonsky
23
mruby36 | 9 years and 4 months ago
object(WP_User)#4969 (8) {
object(stdClass)#4976 (12) {
string(6) "176799"
string(7) "mruby36"
string(7) "mruby36"
string(15) "matt@nyc-hs.com"
string(6) "Matt R"
int(176799)
Cafe Babalu is my fav spot in good ol’ downtown reykjavik.
Boral looks interesting, will check it out. Alternatives to wood are dizzying,
Save a tree – use something else,
cheers!
daveinbedstuy | 9 years and 4 months ago
object(WP_User)#4968 (8) {
object(stdClass)#4967 (12) {
You may have not seen it since it was in the first reply but I mentioned Boral, which is even better.
slopefarm | 9 years and 4 months ago
object(WP_User)#4964 (8) {
object(stdClass)#4970 (12) {
string(3) "655"
string(9) "slopefarm"
int(655)
Glad to make your day. It is a great movie.
A fair amount of corrugated metal siding in Greenwood Hts. it is also the siding of choice in much of downtown reykjavik — holds very bright colors really well.
object(stdClass)#5241 (12) {
string(6) "176799"
string(7) "mruby36"
string(7) "mruby36"
string(6) "Matt R"
int(176799)
LOL I was waiting for that – knew it wouldn’t take long… will have to go rent tin men on netflix. That aluminum stuff is pretty cool though and worth a look. If you’re doing exterior insulation, the rain-screen systems for cladding are great alternatives.
BTW – The Trespa has a pretty good product as well from what I’ve heard. The price is fairly high tho..
object(stdClass)#5242 (12) {
string(3) "655"
int(655)
Are my eyes deceiving me or are we — in 2016 — dealing with an aluminum siding salesman.
object(WP_User)#5241 (8) {
object(stdClass)#4964 (12) {
string(6) "176799"
string(7) "mruby36"
string(7) "mruby36"
string(6) "Matt R"
int(176799)
The concern is “silica dust”. Anyone who works with Hardiboard – for their own sake – hopefully does as you suggest, contain it. OSHA is not quite as confident that such precautions are being taken however. You can read more here: https://www.osha.gov/silica/factsheets/OSHA_FS-3683_Silica_Overview.html – and here: http://www.oshasafetymanagement.com/blog/silica-dust-worker-health-and-prevention/
There are alternatives to Hardie. All are likely to cost a bit more as Hardie is the low cost provider. While alternatives may cost a bit more, in some cases the install labor may be less for a variety of reasons. Mine is just a suggestion that Hardie is not a panacea and having a look at all your options is generally sound practice.
object(WP_User)#5242 (8) {
object(stdClass)#4969 (12) {
I’ve had it up since 2000 at a house. No issues.
object(stdClass)#4968 (12) {
string(3) "655"
int(655)
We have hardieboard and know a bunch of others that do, as well. I don’t know anyone who has had a problem with the planks cracking and falling off.
“environmantal concerns” Yes, dust. Nothing hazardous. Anyone who works with Hardieboard knows how to contain it.
string(6) "176799"
string(7) "mruby36"
string(7) "mruby36"
string(6) "Matt R"
int(176799)
Solid aluminum board siding may be a better alternative – see http://al13.com/v-line-system.html
Hardie is a cementitious fiber cement siding that requires face nailing, which then requires the face nailing to be painted and maintained. The material splits and cracks easily so if the installer misses small hair-line cracks, guess what falls off after a while. Also there are or will be some environmental concerns given the dust generated when cutting the stuff. Contractors that know what they’re doing have vacuums attached to their circular saws to contain the dust and in some cases where
joearchitect | 9 years and 4 months ago
string(6) "176914"
string(12) "joearchitect"
int(176914)
I’ve had good luck with the hardie plank siding. I use the the smooth finish and the “artisan” line which is a little thicker and looks just like painted wood clapboard. I’ll attach a picture of a house with this – it’s on 13th street in Park Slope.
string(6) "176914"
int(176914)
[Wood frame 4-002](//muut.com/u/brownstoner/s2/:brownstoner:V9ut:woodframe4002.jpg.jpg)
object(stdClass)#5244 (12) {
string(3) "655"
int(655)
Add my $.02 to the view that the fake woodgrain looks fake. But best to judge for yourself. If you are at all near the slope, stroll 14th street between 4th and 6th Aves, and 11th street between 3rd and 4th. All of these blocks have houses with hardieboard planks, both smooth and grainy side out. I think the smooth side makes for a classier look when painted.
AndrewPorter | 9 years and 4 months ago
string(4) "7714"
string(12) "AndrewPorter"
string(34) "$P$BJN3X/xb0Xbo6hikBLkt21DodcLo51."
string(17) "andrew-porter-2-2"
string(19) "aporter55@gmail.com"
string(54) "http://www.brownstoner.com/forums/users/andrew-porter/"
string(19) "2017-08-17 21:39:49"
string(20) "AqsqSmxXPbxEC410r7V9"
string(13) "Andrew Porter"
int(7714)
If you’re in a Landmarked area, they won’t allow the use of anything that’s not real wood.
williamsburgguys | 9 years and 4 months ago
object(WP_User)#5244 (8) {
string(6) "179772"
string(16) "williamsburgguys"
string(34) "$P$BcTw5wsxim9sw6gnCR/OE1x0rr8VYR0"
string(26) "thomas.hellmer@verizon.net"
int(179772)
The green house (Hardie) in the picture above is ours (Thanks Cate!). It’s in the finest artificial woodgrain level of the 3 they offered and we chose it over the flat because we wanted an ever so slight aged look. I agree the heavier grained finishes don’t look that natural, but to us the completely flat finish also didn’t look natural. So we took the finest grain and are happy with it. Since this picture was taken the cedar on the left has aged somewhat and is showing a natural grain in some areas where the varnish has aged off, so if they were to ever paint I I believe it would look similar to ours. The owners to our right are getting new Hardie installed with a new cornice in two weeks which will complete our row.
lgwlcvqt | 9 years and 4 months ago
object(stdClass)#5243 (12) {
string(6) "209014"
string(8) "lgwlcvqt"
string(34) "$P$Bco4X0PubGzep2htJkd59TCdDT9PSx1"
string(23) "brodydude2001@yahoo.com"
string(19) "2024-06-21 12:39:37"
int(209014)
We did Hardie in front and vinyl in back and it looks great. We didn’t use the fake wood grain cause it looked cheesy. Flat is typical for Brooklyn but for suburbs and LI the wood grain is the norm. Premier did our work and they were great to work with
dougb | 9 years and 4 months ago
object(stdClass)#5245 (12) {
string(6) "180076"
string(5) "dougb"
string(34) "$P$Br2q0HTR5CEFuU7yVEGeR5P/eS8PuK."
string(5) "dougb"
string(16) "dbruha@gmail.com"
string(5) "dougb"
int(180076)
Hardie makes it without the wood grain as well, might look less fake when smooth.
Augustiner | 9 years and 4 months ago
object(stdClass)#5246 (12) {
Do stucco – comes in all colors and takes a few dollars off your energy bill
jimhillra | 9 years and 4 months ago
object(stdClass)#5247 (12) {
string(6) "180609"
string(9) "jimhillra"
int(180609)
Call up a supplier and get a sample. They may charge you a few bucks, but it’s a lot cheaper than finding out too late.
