Threshold for entry door
We have had a couple of marble thresholds crack. It’s possible the marble had a flaw but. I was wondering if another kind of stone might work better. Granite? Maybe a wood like ipe? Maybe an aluminum/ rubber safety strip?
This would go in a kitchen on a new oak floor, next to a metal piece that forms part of a door frame. I can’t remove that because the door locking mechanism has a pole which drops into a hole on the above mentioned metal thingy. The sub floor is plywood. Another threshold needing attention is in the verstbule on top of mosaic tiles and concrete applied to wood.
Any help appreciated.
markwalker
12
object(WP_User)#4979 (8) {
  object(stdClass)#4991 (12) {
Whoa, if that caulk is to the inside of the door and water does not get under the door and to inside of the wood, you might not have a problem. What i was thinking about was caulk around the bottom of the extended jamb and saddle outside. Any caulk running horizontal on the outside of a home is a potential trap for mousture.
As far as that gap you filled, hand planing the edge of the wood could have closed it up (i hand plane wood when patching wood floors) or sometimes i glue thin strips of wood in. There is a product called lexel. Lexel is like a clear caulk, clearer and harder than silicone. I would not use it on a floor per se because that is not what we do but it might be ok to use around a saddle. The thing is, when lexel dries, it picks up the color of the surrounding wood and hides the gap. Lexel is an easy cheat.
workisfun | 3 years and 3 months ago
object(WP_User)#4980 (8) {
  object(stdClass)#4981 (12) {
    string(6) "184143"
    string(9) "workisfun"
  int(184143)
Airslate?
markwalker | 3 years and 3 months ago
object(WP_User)#4984 (8) {
  object(stdClass)#4978 (12) {
    string(6) "202629"
    string(10) "markwalker"
    string(11) "mark Walker"
  int(202629)
LOL Thanks. We can still scrape it out at this point. [Threshold_3580](//muut.com/u/brownstoner/s3/:brownstoner:4218:threshold_3580.jpg.jpg)
  object(stdClass)#4977 (12) {
That caulk alongside that saddle is going to trap mousture and lead to rot. White oak was a good move. Not sure what else to do but i try to avoid caulking down low on the things and where wood meets concrete or metal.
object(WP_User)#4978 (8) {
  object(stdClass)#4980 (12) {
    string(6) "202629"
  int(202629)
Steve, thank you for being always helpful and giving sound advice. I will check out the stone place when we do the vestibule. In the vestibule area there are old tiles which rest on something fairly immobile.
In the case of the back door onto the deck there is a wood floor and subfloor, really no room (depth) for cement or anything of the kind, and an existing door which cannot be cut on account of its locking mechanism. We wound up installing. a piece of white oak, well coated with spar varnish and cauked where it meets the metal piece. Cheapest, easiest, easiest to replace.
object(WP_User)#4977 (8) {
  object(stdClass)#4984 (12) {
By the way, there is a stone place on like 13 or 14 by like 5 or 6th. A customer ordered a saddle from them a few months back and i had to deal with the drawings and details. The process went well and i would use them again if i were working near there.
  object(stdClass)#4979 (12) {
Somebody from kensington called me a week ago and said they would be willing to pay me $1400 to provide and install one of these. I consider that to be too much money. I told them try to find some local and smart handyman. Dealing with setting this under a pair of doors can sometimes be tricky but not tricky enough to pay 1400. I do not have recs for anyone. Maybe the stone place on 13th st will have someone?
terryhoppy | 3 years and 3 months ago
    string(6) "144730"
    string(10) "terryhoppy"
  int(144730)
thank you; do you have a rec
  object(stdClass)#4976 (12) {
terry, i can but have other pressing things. i do this as side work when time permits.
  object(stdClass)#4956 (12) {
    string(6) "144730"
  int(144730)
steve do you install
object(WP_User)#4976 (8) {
Cate is right. Any stone you put down will break if the substrate is uneven and weight is put to it. That is why we put a mortar bed under saddles as opposed to simply using construction adhesive like pl. That said, pl does take up gaps. So if your substrate is firm and you don’t have enough depth to lay a 1″ plus mortar bed, if you were to lay pl premium thick enough to take up any gaps and you pressed the saddle down into it with support all around, you might get away with it. I might try it in my own house but if i did it in a customer’s house, i would have to tell them it came with some risks.
I put down about 6 entry door saddles a year as part of my door business. I stopped using marble a long time ago because it is soft. I now use quartz or ceasarstone. Ceasarstone is a brand name of quartz. But keep in mind, no 1.25″ inch thick piece of stone can support someone standing on it if it is not supported properly from below.
Steve
cate | 3 years and 4 months ago
object(WP_User)#4956 (8) {
Generally speaking, the substrate should be stable and level, and any pressure applied to it should be even.
