Staining Flooring to Match
Patched a small (10 sq ft) area of flooring, which, after sanding & finishing professionally, looks quite different. Floor guy (not the installer) said it’s white oak (old) vs red oak (new.) Since it’s too much to do a replacement, how best to stain new floor to match? Is trial-and-error on a fresh piece the only way? Can stains be diluted or color adjusted? And finally, is stain from hardware store ok? Thanks.
cmu
in General Discussion 9 years and 6 months ago
curtisqqs | 9 years and 6 months ago
object(WP_User)#4978 (8) {
object(stdClass)#5051 (12) {
string(6) "195320"
string(9) "curtisqqs"
string(34) "$P$BoIkEoPoo0qi9DbIDk3i5eoo/cVqEe1"
string(21) "xrumer888@outlook.com"
string(19) "2024-03-26 09:24:23"
int(195320)
Thank you, for the question. I do agree with Sethamin for the conclusion.
cmu | 9 years and 6 months ago
object(WP_User)#4977 (8) {
object(stdClass)#4976 (12) {
string(4) "1452"
string(3) "cmu"
string(3) "cmu"
string(3) "cmu"
int(1452)
Thanks all.
sethamin | 9 years and 6 months ago
object(WP_User)#4973 (8) {
object(stdClass)#4979 (12) {
string(6) "177093"
string(8) "sethamin"
int(177093)
You can try taking a test piece and target piece to Abbott Paint in Greenpoint, and they should be able to help you build a matching stain. They can use a stain system where they iteratively try to get closer and closer to the target color.
slopefarm | 9 years and 6 months ago
object(WP_User)#4976 (8) {
object(stdClass)#4978 (12) {
string(3) "655"
string(9) "slopefarm"
int(655)
Yes, I think trial and error is the only way. But get some good guidance, I know there is, or at lest was, a higher end stain store somewhere along the BK waterfront south of Home Despot. I don’t remember the name. take some pics with your phone and go there and get some advice. You want higher quality than minwax and there are tints you can buy to adjust stains slightly to help match. But it is not just the color of the stain, the old and new wood may vary on the grain pattern, contrast etc.
