Seeking expert in structural design around vestibule & inner door of brownstone
After two years of reconnaissance, we believe the source of a clothing moth problem is in the walls at the intersection of the front door vestibule, the inner door, and adjacent corner of the livingroom on the parlor floor. The moth nest could also be in the same areas on the floor directly above. In 1-2 months, a trusted expert will inject moth killing spray into the crevices of the walls in this area.
I’m looking for someone who can explain how these areas were built in a traditional brownstone, so that the moth killing spray can be injected in the right places (via cutting a small hole in the walls and pressure blasting the spray inside). I’m also interested in how moths may travel within the walls and spaces between the floors, to determine where else to treat. We did this tretment on a more limited basis last summer, and it was only partially successful. We have tried many other ways to get rid of clothing moths. Almost all areas of the house have been taken care of, but this area remains.
If this treatment doesn’t work, we will probably start to tear down the walls and ceilings of the vestibule to figure this out.
Expert advice about the structural design of these areas would be greatly appreciated. Even to be able to see into a current demo of this area could be super helpful.
Thank you very much in advance!
citizenjane
24
justinromeu26 | 3 years ago
object(WP_User)#5237 (8) {
  object(stdClass)#5047 (12) {
Construction knowledge helps.
hasibur.rahman07 | 3 years ago
object(WP_User)#5058 (8) {
  object(stdClass)#5057 (12) {
    string(6) "193777"
    string(16) "hasibur.rahman07"
    string(16) "hasibur-rahman07"
  int(193777)
I agree with HomeInspector, that it is not that hard to locate studs. You can use a stud finder or an infrared camera. Glad to hear that he helped you out.
object(WP_User)#5054 (8) {
  object(stdClass)#5238 (12) {
You realize i have not stopped thinking about these things and where they are coming from.
citizenjane | 3 years ago
  object(stdClass)#5240 (12) {
    string(6) "181789"
    string(11) "citizenjane"
    string(63) "$wp$2y$10$pO6YlI8sDkBEsfOUY5cG6e5QQoPeYj3SWlHnp7thRR5Xh2I78q0zu"
    string(25) "allisonanywhere@yahoo.com"
  int(181789)
I am happy to share a big thank you to HomeInspector who came out to our house to help with our moth problem. In particular, he identified the location of the studs and beams in the walls and ceilings of our vestibule and the surrounding rooms, so that we will be able to proceed with the moth treatment, getting it into the right places without damaging any other parts of our house. He did this with great attention to detail, good humor, and commitment to helping us get to the bottom of our moth issue. And he was very generous with his time. With his help, we are making progress. Thanks again HomeInspector!
object(WP_User)#5238 (8) {
  object(stdClass)#5058 (12) {
The construction of these walls may seem unique or difficult for people who have never done this stuff but for those of us who have, the framing in these houses is very simple. An engineer would be overkill. An engineer is needed to move walls.
I just ordered a borescope.
object(WP_User)#5240 (8) {
  object(stdClass)#5054 (12) {
    string(6) "193777"
  int(193777)
I’m sorry your situations sounds so frustrating.
https://www.arbico-organics.com/category/moth-egg-parasites?
  object(stdClass)#5237 (12) {
    string(6) "193777"
  int(193777)
Engineer http://afminspections.com Tony Marmo
I would need the heat on warm inside and the vestibule cold. I just did it here.
Why not email me.
    string(6) "181789"
  int(181789)
@HomeInspector – Using a bore scope is an interesting idea.
Re: thermal imagine detector, our vestibule is not heated – you would be more than welcomed to try out your thermal imagine detector there for finding studs. We could even turn off the heat inside the house to help. But I realize this may not be convenient. (BTW, we have a cheap stud finder and it has also never worked.)
Do you think that it might be possible to find the original architectural drawings for the house with the city somewhere?
Finally, there is still a very small chance that somehow moths are coming in from the outside through some cracks in the front door (even though it was deemed likely impossible). Perhaps we should get the front door re-hung, but we are on a limited budget.
Oh, the joys never end… 🙂
    string(6) "181789"
  int(181789)
@vard01 – Thanks for sharing your ideas. We think the moths are in the walls because we have no carpets, open clothes, etc. and they are coming from the vestibule area which is airtight. we’ve been dealing with this for 2+ years. AND there is horse hair in the lath and animal hair is a favorite source of food for clothing moths.
Re: biological exterminants (wasps), do you know of any source in the US? or anyone who used them for this purpose who could serve as a reference?
Finally, might you know of any structural engineer who would be willing to speak with me about vestibule design and the nexus of walls in that area and in the inner side of the door (ie in corridor and parlor floor living room)?
Thanks again!
Right. It would take a mass. The thing about the moth nest is it becomes a mass of yuck.
    string(6) "193777"
  int(193777)
Yes you may spot a nest not individual pests. Based on the heat maps, it would be possible to open small areas and check for pests. Opening plaster is not the easiest.
I pasted a Canadian link for the wasps but there are US sources.
Thank you vard. My thought is, and i read this elsewhere, the moth nest will form a blanket of heat or insulation which will change the temperature of the wall.
Most of the inside vestibule walls are simply studs and plaster. Nothing fancy.
    string(6) "193777"
  int(193777)
    string(6) "193777"
  int(193777)
Btw I had clothing moths and they usually like to live in carpets and upholstery. I don’t think they would be in a vestibule with no fabric. What makes you think they are in there. Sorry if I missed this somewhere.
No studs in that area in my house. Just brick and wood. but that’s not to say someone else’s house is different.
    string(6) "193777"
  int(193777)
You can see studs not sure you can always see pests. Usually the vestibule is brick with wood enframement next to the door areas. Why don’t you call a structural engineer and ask over the phone?
    string(6) "181789"
  int(181789)
ok.
Hey, i need to play with this more. I can not get the studs to show up in my house with the walls heated. I want to find a house with an internal cold vestibule with heated rooms on the other side to see if i can spot studs. I cannot do it on my house as the vestibule is extrrior and brick. No sticking.
    string(6) "181789"
  int(181789)
Hi HomeInspector and cate, Thank you so much for your input – that is super helpful. I somehow missed your responses (was out of town for a week). Thanks for helping explain the construction design of the vestibule area and surrounding walls. The thermal imaging camera sounds like it could be super helpful. I will digest all of this info and provide a full response tomorrow (Tuesday). THANK YOU! 🙂
