Radiator directly against Sheetrock wall?
Is there any issue (besides painting) with installing radiators basically directly against the wall?
I want to add at least 1” of rigid foam insulation to a cold exterior wall but it will bump out the wall and the radiators will be re-installed with no gap between them and the wall.
Any thoughts on if this is an issue?
stickerhappy
in General Discussion 5 years and 7 months ago
Master Plvmber | 5 years and 7 months ago
object(WP_User)#5008 (8) {
  object(stdClass)#5053 (12) {
That’s the hotter medium but it’s still fine.
stickerhappy | 5 years and 7 months ago
object(WP_User)#5009 (8) {
  object(stdClass)#5010 (12) {
    string(6) "100776"
    string(12) "stickerhappy"
  int(100776)
It’s steam heat
object(WP_User)#5013 (8) {
  object(stdClass)#5007 (12) {
Slightly. Not enough to affect room temperature. Also, is this a steam heat or hot water heating system? Steam runs at about 215° surface temperature and hot water generally around 170° on average.
object(WP_User)#5010 (8) {
  object(stdClass)#5008 (12) {
    string(6) "100776"
  int(100776)
Will it impact air flow and heat output?
object(WP_User)#5007 (8) {
  object(stdClass)#5009 (12) {
It’s not an issue. It won’t get nearly hot enough to matter.
