Plumbing-Check Valve question
As a follow up to my “Sub Pump *pipe* replacement” post which is now closed. I want to replace the check valve (attached photo) along with the new steel galvanize pipe I bought. Is the check valve the right one to buy to use with a steel galvanize pipe? Is the check valve just the middle black piece? I called one store not close to home they said it was the wrong check valve? I cant seem to find the check valve I went to 2 local plumbing stores and Home Depot. [CheckValve](//muut.com/u/brownstoner/s3/:brownstoner:di9M:checkvalve.jpg.jpg)
allyslope
in General Discussion 5 years and 8 months ago
ellenlourie | 5 years and 8 months ago
object(WP_User)#5012 (8) {
object(stdClass)#5037 (12) {
I see what looks like reducer. Keep in mind that valves, pipe and fittings must be not be less than pump connecting size
Master Plvmber | 5 years and 8 months ago
object(WP_User)#5013 (8) {
object(stdClass)#5014 (12) {
What he ∆ said.
Guest User | 5 years and 8 months ago
first of all it is a sump pump…..you can use any check valve that is the appropriate size
https://www.google.com/search?q=sump+pump+check+valve&client=safari&rls=en&source=lnms&sa=X&ved=0ahUKEwjBhajAkYDrAhUNhXIEHdJ_AtAQ_AUImgIoAA&biw=1280&bih=689
