Plumber recommendation for Duravit wall mount toilet?
Hi, we have a great plumber, Willie Puig, for our occasional plumbing problems but he doesn’t know anything about wall mount toilets. One of ours — they are Duravit, with Geberit tanks — likes to run and I can’t figure out on my own how to fix it. Can anyone with wall mounts recommend someone who has experience with them? (Other than this, btw, the toilets have been flawless.) We’re in Bed Stuy. Thank you!
robertbullock
15
cate | 2 years and 6 months ago
object(WP_User)#4960 (8) {
  object(stdClass)#4984 (12) {
Lol!
lkrshacmzcy | 2 years and 6 months ago
object(WP_User)#4974 (8) {
  object(stdClass)#4961 (12) {
    string(6) "209518"
    string(11) "lkrshacmzcy"
  int(209518)
As a Plumber, I support Wall Hung Toilets and Augstiner’s take on them. Why?
They break twice as much as a simple gravity tank and bowl.
Handymen can’t work on them so the competition of services drops by at least a third
Because of the above, the cost is four times as much on Repairs, Replacements and Installations. …
In other words: Great for Great companies!
object(WP_User)#4955 (8) {
  object(stdClass)#4962 (12) {
    string(6) "209518"
  int(209518)
Master Plvmber | 2 years and 6 months ago
  object(stdClass)#4963 (12) {
> @Augustiner
> There is no question that Euro wall hung looks better, is more hygienic, easier to clean, more space efficient, uses less water per flush and outlasts all your Home Depot bowls by decades.
Whaaaaat??
“Looks better” Subjective. “More hygienic” Where on earth did you get that from” More space efficient” Ok. Yes. “Uses less water per flush” Some times but not by default. “Outlasts all your HD bowls by decades” Not a chance. They require far more repair than standard American style toilets and they use costly proprietary parts that are *always* hard to find.
robertbullock | 2 years and 6 months ago
object(WP_User)#4962 (8) {
  object(stdClass)#4974 (12) {
    string(6) "183080"
    string(13) "robertbullock"
    string(34) "$P$BONKUP/qGibK9baiRbpqcbUjA.fGJI1"
    string(18) "rbullock@gmail.com"
  int(183080)
Thank you all for the suggestions! I will try out youtube for starters. I’m not very handy but will give it a go. I’ll go to a plumber if I have to afterward. Fwiw, besides the fact that our go-to plumber doesn’t know anything about them, I like the Duravit toilets a lot for the reasons above. Thanks again!
Augustiner | 2 years and 6 months ago
  object(stdClass)#4964 (12) {
Now I’m personally offended 😉
And don’t get me started on those low rider bathtubs that maybe fit a 5 year old
amt230 | 2 years and 6 months ago
  object(stdClass)#4960 (12) {
    string(5) "12905"
    string(6) "amt230"
    string(63) "$wp$2y$10$eFG.8CHc0xsWBE4/12mbVOncRXguZKYzuQx/qnLYvC4KU6SkMssRG"
    string(6) "amt230"
    string(21) "adam.tomiak@gmail.com"
    string(6) "amt230"
  int(12905)
Haha, MasterPlumber is right, the toilet brush is now an essential component in our bathrooms with these toilets. But, for us, the design still makes it well worth it. More than aesthetics (which are, indeed, SO much better) it allowed me to configure roomy bathrooms in a small space that would have been impossible with a traditional tank toilet. Of course, check in when I have my first issues and need to open walls to resolve, but I’m still on the balance very happy with them. I also have made adjustments successfully using those bars to the flushing mechanism, if you haven’t tried that yet. Otherwise, yes, any plumber should be able to handle (but you may need a contractor based on the extent of your problem!). Good luck!
  object(stdClass)#4965 (12) {
I agree with you. They look great but Europe has nothing to teach the US when it comes to bathroom design. They seem to just love using a toilet brush.
tetz | 2 years and 6 months ago
  object(stdClass)#4966 (12) {
    string(6) "189983"
    string(4) "tetz"
    string(34) "$P$BXGPCV9JBp8FFsOie65u9JcQBphAi30"
    string(4) "tetz"
    string(14) "tetzeli@me.com"
    string(19) "2024-02-22 16:47:21"
    string(39) "Rick tetzeli@me.com Rick tetzeli@me.com"
  int(189983)
wall mounted is the worst.. i paid to strip my wall mounted for a normal one after I did a full gut reno. So i had to find the same wall and floor tiles to match the ones I just put in!
object(WP_User)#4965 (8) {
    string(6) "189983"
    string(4) "tetz"
    string(4) "tetz"
  int(189983)
  object(stdClass)#4967 (12) {
I’ve had lots of problems resolved by adjusting the length of the push-panel linkage.
  object(stdClass)#4955 (12) {
There is no need to remove Sheetrock. And wall hung Geberit systems have most plumbers scratch their head.
Remove the wall flush plate and have a look. YouTube ‘Geberit running’ shows 2-3 videos with that issue. For example this amazingly detailed tutorial https://youtu.be/m7zlPmgbY1M?feature=shared
object(WP_User)#4967 (8) {
    string(6) "209518"
  int(209518)
Most Plumbing Companies should have experience with an In-Wall Toilet; they are pretty standard
    string(6) "209518"
  int(209518)
Do you have access to the tank? You may have to break through a closet wall or such to get at it.
