Plaster skim coating recommendations
Does anyone have any recommendations for a plaster expert they have worked with who does skim coating? We would like to skim coat the walls in two parlors, no ceiling work. In one of the parlors, the crown molding has cracks and needs resurfacing (maybe not on all four sides of the room but probably on three). (I did see JaneDrew’s reviews for outfits that do hot-run molding.)
cate
cate | 4 years ago
object(WP_User)#4996 (8) {
object(stdClass)#5050 (12) {
Thank you!
mangumbuilders | 4 years ago
object(WP_User)#4989 (8) {
string(6) "189492"
string(14) "mangumbuilders"
string(34) "$P$BleGsL/KszTba.zz5uJagRbKu4IqpE/"
string(26) "MangumBuilderstx@gmail.com"
string(19) "2024-02-22 16:45:22"
string(31) "Mangum Builders Mangum Builders"
int(189492)
We had work done by Bestwall Plastering ,they skimmed coated 4 rooms including ceilings ,they used Diamond plaster ,no sanding involved . Bestwallplasteringblog to see there work
Hope this helps. Contact Bryant 917-415-6215
cate | 4 years ago
object(WP_User)#5050 (8) {
object(stdClass)#4991 (12) {
Thank you so much, Jeremy.
Guest User | 4 years ago
Calvin of Right One Interiors (718) 877-2566 does a lot of paint and plaster work for us
