pervasive funky smell (not from humans) in bathroom (w/skylight but no filter)
The contractor suggested the old shower stall was degrading and causing this smell…never heard of that sort of thing. Any suggestions? We didn’t renovate the bathroom (tho we did other parts ofthe house) just put in new tile. Thx!
gussie13
stevecym | 6 years and 8 months ago
object(WP_User)#5118 (8) {
  object(stdClass)#5106 (12) {
well, the toilet is the trap and the sink trap they should be sure is full. we are not talking about the house trap. I cannot think of a reason for the trap until the lav to drain unless it is itself leaking.
object(WP_User)#5117 (8) {
  object(stdClass)#5116 (12) {
ok, i just looked it up. Studorvant. they call it just what you do. i never saw one in NY. are they legal here?
object(WP_User)#5113 (8) {
  object(stdClass)#5119 (12) {
@mdr, I am not a plumber. I can probably google this just as well but your term “air admittance valve” just made me think of something I saw when I was working on a project in north Carolina (I mention the place as codes were lax down there). they were converting an old commercial/warehouse into apts and instead of running roof vents for the waste stacks, they put this little pipes with something on top of them in the wall behind each commode. I remember thinking, that looks like something that will stink one day. I think it was called a “studivent” ( i was so curious about this i did go up to it and study it as i had never seen anything like it in NY). is that an air admittance valve? i am hoping when i google Studivent or Sturdivent that i find the company has folded.
  object(stdClass)#5127 (12) {
Steve,
You’re correct that a blocked vent wouldn’t cause an odor IF there was water in the traps, but how is the OP to know if there is, or isn’t water there?
MDR | 6 years and 8 months ago
object(WP_User)#5082 (8) {
  object(stdClass)#5055 (12) {
    string(6) "170560"
    string(3) "MDR"
    string(3) "mdr"
    string(3) "MDR"
  int(170560)
@stevecym if the water gets pulled out of the trap then yes, you will have smelly sewer gases coming up the drain pipe. A proper vent is unlikely to become blocked, but if there is no vent, or if someone used an air admittance valve instead of a vent and that stopped functioning, then it could lead to gases coming up the drain.
object(WP_User)#5083 (8) {
  object(stdClass)#5081 (12) {
hey bob, not to knock you, but I am trying to think how a blocked waste line vent could do that if the traps and commode have water in them? I can see a block vent causing the water to get pulled out of a trap.
cate | 6 years and 8 months ago
  object(stdClass)#5118 (12) {
Does it smell like mushrooms and/or ever changing funky smells ranging from boiling potatoes to kind of sewage-waste? If so, it’s very likely mold/fungus caused by a leak of some kind. Could be the shower stall your contractor suggested. Could be other aspects of fixtures, including even condensation on the toilet. Could even be a skylight leak down air shaft adjacent to the bathroom. If any of your fixtures are mounted on stone on a wood floor, any drip of water from, say, your hand, can reach the wood floor and cause a smell. The list goes on. Love to know more.
dorkofwindsor | 6 years and 8 months ago
Could you describe the smell in greater detail?
  object(stdClass)#5132 (12) {
It might be a blocked vent on the waste line.
