Permit for swapping gas stove? Sink?
Do you technically need a LAA permit and plumber to swap out a gas stove? I’m not talking about moving it or the gas line. Just simply replacing an existing one in the same spot.
What about for replacing a toilet or sink in the same spot?
I thought you didn’t need a permit, but someone recently told me that technically you’re supposed to do a LAA, but for those types of things no one ever does.
cate | 6 years and 8 months ago
object(WP_User)#5056 (8) {
  object(stdClass)#5068 (12) {
AFAIK it’s completely legal for anyone to swap in a new toilet for an old one without a permit or a plumbing license. As long as you don’t move the location of the fixture. That requires a permit and a licensed plumber.
stevecym | 6 years and 8 months ago
object(WP_User)#5055 (8) {
  object(stdClass)#5054 (12) {
what about changing plumbing fixtures? any change in the code there?
string(6) "199384"
There is no way you need a permit to put in a new stove/range. You’re just turning off the valve, rolling the unit out and popping in a new one. Could not be simpler.
mattieweiser1
object(WP_User)#5086 (8) {
  object(stdClass)#5045 (12) {
    string(6) "190802"
    string(13) "mattieweiser1"
    string(34) "$P$B3pYXrcTYGc12hwKujTqngzL.fLzxo1"
    string(26) "Mattie.weiser@corcoran.com"
    string(19) "2024-02-22 16:53:31"
    string(27) "Mattie Weiser Mattie Weiser"
  int(190802)
I do not believe a permit is required if you are not re-routing any services but merely replacing fixtures. However, if you are part of a coop you should double check with them.
object(WP_User)#5053 (8) {
  object(stdClass)#5046 (12) {
burnt toast: I am hoping someone else chimes in here to confirm or refute what I am saying; if they do not, I will get an answer for you.
object(WP_User)#5089 (8) {
  object(stdClass)#5056 (12) {
with respect to what i wrote above, i just looked the LAA up and some of this sounds new. by what i read, i wonder if they do require a permit to change these things. let’s wait and see what others say and i might dig deeper later. in the old building code, a permit was not needed to change a sink or toilet. i am not sure about changing a shower pan or built in tub. stove, so long as we did not touch the fixed, hard piping, we were ok. and with all of this, we could not relocate.
object(WP_User)#5046 (8) {
  object(stdClass)#5086 (12) {
a plumber once told me that so long as you are not touching anything before that flexible gas line, anyone can legally disconnect the stove and connect a new one. it is not considered plumbing and my take on that is if it is not considered plumbing, than it will not need a permit. the same on the plumbing fixtures. anyone can change a fixture (another plumbing who writes on here told me otherwise, but i found it in the codes) so long as you do not move the fixture. once you open walls and move pipes, you need a plumber and my guess is it must be filed. if someone comes on here and says otherwise, i will go through the codes and find the answer.
