Oil Tank Leak?
We recently had a very smelly oil delivery. A quick look revealed some oil may have oozed out from the coupling where the oil pipe meets the oil tank. We had our oil pipe replaced about a year ago. If this coupling is now leaking, could this be caused by faulty delivery (too much or too fast?) or is it possible when the new pipe was put in, they didn’t put pipe dope or whatever you are supposed to do on the coupling to seal it? Thank you.
cate
in General Discussion 5 years and 6 months ago
cate | 5 years and 6 months ago
object(WP_User)#5007 (8) {
  object(stdClass)#5053 (12) {
Thanks, Steve, that is very helpful. Someone came out from the oll company to inspect today. Tightened a loose coupling on the vent pipe and told me me our new vent pipe is bigger than the old one per new city requirements, and when the deliveries are made, there is more of a smell than there used to be. Fingers crossed the tightened coupling lessens the smell after the next delivery because I don’t think we could stand it otherwise.
stevecym | 5 years and 6 months ago
object(WP_User)#5008 (8) {
  object(stdClass)#5009 (12) {
cate: i do this stuff in my own house but would not do it for a customer, especially not oil as it would be an environmental disaster if something went wrong. i did change (alter; when i switched oil tanks) my own pipe and i know i put something on it. it is a few years now and i have all sorts of pipe dopes and i buy them per situation so my guess is, i read the can and it said diesel or oil or something and that is what i used. i do not think i used thread tape on it. since i do not do this every day – or even every year, i have to ask as i do.
i do believe that if you smell it, something is not correct. i was in a customer’s house once and out of all the houses that have oil, only that one did i smell the oil. i told the customer, something is not right.
object(WP_User)#5053 (8) {
  object(stdClass)#5013 (12) {
Great, thank you so much for this very helpful info, stevecym. If any plumbing, heating, or HVAC experts are reading, maybe you could tell me if the people who installed the new pipe should have done something to make that coupling not leak. Thank you.
  object(stdClass)#5006 (12) {
hey cate: a couple of things. the delivery is always fast. very high volume. like 100 gallons in 30 seconds. also, they frequently over fill them. i knew someone whose job it was to dig contaminated soil away from the over fill (whistle) outside houses. none of this should cause anything to leak. so if it did leak there is something with the piping.
object(WP_User)#5013 (8) {
  object(stdClass)#5008 (12) {
Maybe one of the plumbing, HVAC or heating experts on the Forum has an opinion on this.
